Non-permanent way of gluing aeroports?
I have them duct taped together right now. Looking for something a bit more solid since mine are pretty long - full length plus another 9" section.
Issue is I don't want to use PVC glue because it's irreversable. If I need to make changes to my ports... Well... Do the math. 5 aeros plus 5 extra coupling rings plus 5 extra tubes. $$$
Are they butt or sleeve?
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
I don't use duct tape but the actual foil duct tape. It holds a lot better and isn't that expensive. You can get a roll at Lowes for ten bucks and it holds like a boss. I've also used silicone in the past and it will pull apart under enough pressure.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
Ever use gorilla tape before? Stuff is nuts. Prepare to lose your fingerprints once your done using it lol.
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Silicone eh? Never thought of that one
They are two equal diameter pipes with a sleeve that slides over the seam. Note that the sleeve doesn't have a lip on the inside to hold the pipe as I've seen on the plumbing variety
Kind of like this
  • Who's Online   0 Members, 0 Anonymous, 3357 Guests (See full list)
