has any one ever used regular solid stranded 1/0 or 2/0 electrical wire as power or ground instead of Multi-strand wire
i know regular wire is harder to mold into shape and terminate
but could it be use for jumping battery to battery or frame to batt / alt to batt
what would be the neg/pos
less current and amperage?
bad connections?
btw im a electrician so i have alot of 2/0 a laying a round. i was thinking about beefing up my grounds frame to rear batt
any ideas thanks
There has been at least 2 people on here that used solid wire. That's all I really know to answer, lol
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Only bad thing is just it's not flexable. And also depends what kind of 2/0 are you using copper or aluminum??
Electrons which make up your electrical power don't actually flow through the wire, they flow around the outside of it. The outer surface area of the wire is what trasmits the electricity. A solid wire, even with a large gauge will transmit far less power than a similar sized wire made up of many individual strands. The higher the strand count, the better the transmission of electrons. Depending on the application, solid strand wire may work, though I can't recommend it. Having said that, a few years back I used wire from Home Depot (can't remember the name of wire) that was about 9 strands of relatively thick wire. It was ok for powering my WalMart amp but I can't recommend it for much more.
Long story short: More strands, More power.
That would make sense if it were high frequencies and AC current.
But when it is DC current, the skin effect in not in use.
Krakin's Home Dipole Project
I'm pretty sure electrons flow though the wire and not around it in dc...
1997 subaru legacy outback
Four 15's in a almost wall
Rockford Fosgate t2500-1bdcp
Rockford Fosgate T400-4 on tweets
Rockford Fosgate T400-4 on highs
Rockford Fosgate T400-2 on midrange
Rockford Fosgate T400-2 on midbass
Optima Yellow top batteries
270A Singer alt (working on a bracket for a second)
Lots of Second Skin
Also, if you are using solid copper make sure you coat it or tin it. If you don't it will oxidize. When copper oxidizes, it becomes a less effective conductor. This means that, in time, the wire's current carrying capabilities will become significantly reduced. This problem becomes worse if you go with OFC (untinned) strands as there is tremendously more surface area.
Jeremy%20Power%20Clarkson_thumb%5B8%5D.j
Lots of Second Skin
  • Who's Online   0 Members, 0 Anonymous, 1398 Guests (See full list)
