gckless Posted July 9, 2014 Report Posted July 9, 2014 Just remember to aim the fan across the heatsink, and push/pull config would be best. Seen a lot of guys just put the fans under the amps, which isn't doing a thing aimed at the bottom cover. Heatsink is where all your heat dissipation is. All you have to do is help it out a little "Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand. My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/ High resolution photos: Gilbert Kless Photography
zack_e89 Posted July 9, 2014 Report Posted July 9, 2014 Do fans even help that much? (If the heatsink is doing it's job?) 97 Suburban 8 custom PSI Platform 3 18's
gckless Posted July 9, 2014 Report Posted July 9, 2014 Do fans even help that much? (If the heatsink is doing it's job?) If you stand in front of a fan, are you cooler, even though you're sweating? "Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand. My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/ High resolution photos: Gilbert Kless Photography
tacomaguy1 Posted July 9, 2014 Author Report Posted July 9, 2014 Even moving around hot/warm air is better than nothing the way I'm seeing it ^ what he said Team Flex Issues
never knows best Posted July 9, 2014 Report Posted July 9, 2014 i've heard of "hot spots" being created by improper fan installation... so I guess you could do more damage than good- push pull method, like stated above, would be the way to go-
tacomaguy1 Posted July 9, 2014 Author Report Posted July 9, 2014 push-pull would be nice, but amps are pretty much just out in the open so not sure how I'd set that up Team Flex Issues
tacomaguy1 Posted July 9, 2014 Author Report Posted July 9, 2014 I've spaced them out further but thinking fans on the left side blowing across amps Team Flex Issues
never knows best Posted July 9, 2014 Report Posted July 9, 2014 i was thinking mounting one to each side of the bottom cover... one push one pull...
omg_spoon Posted July 9, 2014 Report Posted July 9, 2014 Def push pull. 98 Mustang GTSinger 3202 12" Incriminator Death Penalties1 SAZ-2500dv22 D3100,1 D34002 Crescendo CZ-65SAX-100.2Door panels by Diablo Kustomz
Kyblack76 Posted July 9, 2014 Report Posted July 9, 2014 on the back side Tim, and "shoot" it towards the rear window.. Crack your spacing a bit more.... also. Thats what id probably do on your set up Im gonna do a left to right push.pull design also. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
