Purchased a SAZ-2000D and going to order an X12 woofer.
What is the maximum speaker cable size allowed. Could I use 8 gauge OFC power wire to wire my sub to my amp??
Thanks
Also can I use 16 gauge OFC speaker wire as my remote turn on from my HU? I would do 1 run of this and then run it to both of my amps in the back. Am I better off using 12 or 14 gauge or just stick with 16?
Edited by Syphlyn
Syphlyns 2000 F150 4.6L V8
H/U: Kendwood KDC-X898
Speakers: 4 x Alpine SPR-68 Speakers
4 Channel Amp: Alpine PDX-F4
Sub: Sundown Zv4 12
Sub Amp: Sundown SAZ-2000D
Box: 2.75 Cu Ft @ 31Hz
Alternator: Mechman 250A elite series
Wiring: All KnuKoncepz 0 gauge OFC + KnuKonceptz Krystal RCAs
8 gauge will be fine.
I always use 6 gauge from Electronbeam.com
Okay, ordering this all from the states so I can't get anything wrong!
what about the remote wire...?
Sub: Sundown Zv4 12
16ga is fine for the remote wire and you should be able to split it for two amps no problem any more than that and you will need to run a relay.
Do you have hardware stores in Canada?
Well but Its way cheaper online and since i'm ordering the shipping is relatively free. Go to any audio shop up here they want $5 for ONE 1/0 gauge ring terminal. I can get them online in the USA for 1.75 ea.
Edited by Syphlyn
Sub: Sundown Zv4 12
I would go either 8 or 6 guage for speaker wire, preferably 8 guage. For the remote, three is usually the most you want to do off of one line out with out a relay so two would be fine.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
He's correct on that point. I live in southwestern Ontario and the price that retailers charge for the accessories up here is insane.
I settled on everything I needed to do my install and ordered it from Knukonceptz. I did my entire car including big 3, amp install kit, speakers and distribution block for 200 bucks. Locally it would have cost 4-500.
Murdoc
06 civic sedan
alpine cde-hd149bt
sundown sax 150.4
sundown 6.5cs
sundown sd-2 8v2 (pair in a sealed box)
The local shops want $300 for a stinger 1/0 amp install kit. Like wtf?
Sub: Sundown Zv4 12
  • Who's Online   1 Member, 0 Anonymous, 500 Guests (See full list)
