gckless Posted September 23, 2014 Report Posted September 23, 2014 I say another positive run not worth it. Ground run might be worth it depending on what you're doing for grounding now. Just IMO of course. "Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand. My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/ High resolution photos: Gilbert Kless Photography
SPL.Pantie.Soak Posted September 24, 2014 Report Posted September 24, 2014 Im not trying to steal the thread but I just got a Mechman 370 and have the same Amp so I'll add another run given 1/0 is only rated to 350 before it burns and I want to be safe....not to mention I'm wiring to 0.5 Thanks for helping me out Forum Thugs Kenwood KVT-614 (4) Marathon 155 AH batts 2/0 OFC SHCA Mechman 370 (2) Audioque 3500.1 (2) AA Mayhem 15s
hoit Posted September 24, 2014 Report Posted September 24, 2014 ^this! not trying to steal as well. but im in a real similar situation...big three 1/0 ofc, singer 200a, d3400 under hood, one in rear, considering a second run. running two X10s on saz3500 @ 1 ohm (might pick up a saz5000, which would alter things substantially I would think) the 3500 would have to have a dual input, but that's no big deal...and i'm a lil confused on the whole running another ground so..I guess just add up the total amps needed Vs. how many I can offer/ whats lost in the run? ??? 2007 Chevy Aveo Ls sedan 2 Sundown Xv2 on scv4k @ .5 ohm 2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm Big Three, Three runs 1/0 power from front to back, 1 ground front to back Two runs ground from rear bank to chassis XS power d3100 upfront, 3 Odyssey 2150s in bank Singer 220 amp alt
poorfish88 Posted September 24, 2014 Report Posted September 24, 2014 The amp has dual 0 gauge imputs. I, d do it2 runs. A lot of people gave you great advice. But a second run doesn't cost that much. After all the money you dropped on the rest of your system. Why chance it? imho?
MrSkippyJ Posted September 24, 2014 Report Posted September 24, 2014 http://www.stevemeadedesigns.com/board/topic/147995-ground-to-the-chassis-or-run-a-ground-cable-ce-auto-electric-supply-partners-with-damore-engineering-to-answer-video-on-pg-5/ F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
SLYentist Posted September 25, 2014 Report Posted September 25, 2014 To be safe, if you're pulling more than 200-250 amps, add an additional ground before you go adding more power runs. Cables and wires almost never fail; the terminations do.
poorfish88 Posted September 25, 2014 Report Posted September 25, 2014 In truth with this small system a 0 gauge ground run to the batt would hurt the voltage. The cars frame is a better ground on small system,and the car has a steel frame under 4000 watts. Most of what I've said I learned from Tony Candela and Tony D, two Car Audio Gods. In the op case I'd run a second ground to the frame to match the second run of pos from the batt, that's pretty much standard.
audiofanaticz Posted September 25, 2014 Report Posted September 25, 2014 If you do run a 2nd run id try to get the same brand wire for ocd reasons, but also for its size reasons. Also make sure that your 2nd run is the same exact length as your 1st run. If one wire is longer than the other, the shorter wire will have the path with least resistance and will be used more than the longer wire and that longer wire most of the times, unless that shorter wire is at its max capacity.
poorfish88 Posted September 25, 2014 Report Posted September 25, 2014 If you do run a 2nd run id try to get the same brand wire for ocd reasons, but also for its size reasons. Also make sure that your 2nd run is the same exact length as your 1st run. If one wire is longer than the other, the shorter wire will have the path with least resistance and will be used more than the longer wire and that longer wire most of the times, unless that shorter wire is at its max capacity. Dam, I didn't know they should be the same length. Jesus, that's like electric 101, you can tell I slept a lot in school.Thanks for the knowledge.
