Fusing between alternator and battery?
I don't run one on my Mechman. I called them to ask about this and they told me the decision was up to me. If it made me sleep better, then do it. Otherwise, no big deal. As others have mentioned, I have 300 amp fuses on my 2 runs of + to back batteries, then fuses off my batts to amplifiers (4 in total for sub system).
This is kind of off topic, but anyway... Make sure to ground the alt casing to negative post if running a Mechman though. They REALLY stressed that to me, just FYI...
2013 Toyota Camry SE
240a MechMan HO Alternator
1/0 Welding Flex Cable Big 3
CT Sounds 4000.1D
Kenwood XR400-4 Mid/High Amp
SoundQubed Q4-120 Mid Amp
Infinity Kappa 6.5 components
Kappa 6x9's for rear deck fill (coming out)
(4) 8" PRV 8MB450's
Set of SoundQubed SuperTweets
(2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure)
(2) SQ HDC3 10's @ 33.5hz (current build, loving them)
Pioneer AVH-X4600BT
100 sq/ft Stinger RoadKill Sound Deadner
120 sq/ft QMat Sound Deadener
(4) Juice Box Black Cherries
Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0
2 Runs of 1/0 Positive front to back
ToolMaker Everywhere
i never do. do ur stuff correctly everything will be good
REFF'S
My link
EBAY
i don't put a fuse there, but i take extra care in running power wire to keep it away from any moving or hot (exhaust) parts. Running the regulator without the battery connected is bad, and shorting out the battery is also very bad. Balance the risks and make your decision.
Cables and wires almost never fail; the terminations do.
I don't fuse between the alt and batt either
2007 Ford Focus SES Hatchback
Pioneer HU
4 Digital Designs 9515i's in a B pillar.
2 Soundstream XXX 15K's (running at 16 volts)
Soundstream Mids/Highs in custom door panels (getting rebuilt soon)
Soundstream TA2.160 and TA2.400
Sky High and KNU wiring
3 Banks of Maxwell caps
Winston Lithium (not a fan)
Bump4Life 250 Amp Alt. aka USAlternators
Soundstream Focus and Avenger Build Log
Instagram @p4linnovation
YouTube: Team Blowin Loud
I don't fuse here but run is less then 18 inches. Some with long runs to battery will fuse. I run Mechman here so I follow the directions what they said not to fuse.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
I originally planned on running a fuse and bought one... but once I got it and saw it came with a 300A fuse and I didn't have the time or money to run across town to get a lower rated one, I just ran it without one. Works fine for me... hope my car doesn't catch on fire lol
Copied from our web site ( http://www.ceautoelectricsupply.com/big3kitstop.html ):
FUSE THE CHARGE LEAD OPTION
Most OEM charge leads have a fusible link on them. Its purpose is to protect on-board electronics in the event that the regulator fails and causes "voltage run-away." Although this is quite uncommon, fusing the charge lead included in any of our kits provides the same protection for your larger than stock alternator.
When choosing this option, we'll include a Rockford Fosgate ANL Fuse Holder, a 100A / 125A / 150A / 200A / 250A / 300A fuse (your choice), and mounting hardware. In addition, we increase the length of the charge lead by 1 foot to allow you to choose a good mounting location for the fuse holder and still have a nice smooth run from the alternator to the battery.
Tony Candela - SMD Sales & Marketing
Email me at [email protected] to learn about becoming an SMD Partner!
I did put a fuse between my alternator and battery. It wasn't a particularly short run and made me feel better. I also did it for the same reason that snafu posted. Since there was a fusible link on the stock charging lead, I felt like I should just in case.
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
  • Who's Online   1 Member, 0 Anonymous, 679 Guests (See full list)
