Fusing between alternator and battery?
Yeah mechman strongly advises against fusing on the alternator run. They said it's completely safe as long as your wires are run smartly.
Fuse for your wiring, so if you're using 1/0 OFC 300a is fine.
I could've swore that in my instructions from Mechman it said to fuse the charging lead. I may be mistaken, it's been over a year since I've looked at the instructions. To me it's a smart idea. If you were running power to an appliance in your house you wouldn't bypass the main breaker in the house and hook it directly to it, because of the possibility of a power surge. If the regulator goes out on the alternator not only would you have to replace/repair the alternator, but you would have to replace any other electronics or batteries it had damaged from charging too high.
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
fuse it. dont be lazy
Hardly about being lazy, I have the fuse holder here. I emailed mechman and as snafu stated even if the voltage regulator went it wouldn't pop the 200A fuse, but the voltage would definitely increase.
The only way a fuse would pop if the voltage regulator went was if the amperage exceeded 200 amps (my fuse rating).
I know snafu knows his stuff but shouldn't we listen to the people who make the product? They wouldn't sell you something and then tell you to do something that could mess it up, that would be a terrible business plan.
edit: it seems the sides are pretty much 50/50 on here...
It's not the alt you need to be worried about its the rest of your cars electrical system, if the regulator went that means the Alt is already damaged and will need repair.
But what I'm saying is even if I put a fuse and the regulator goes, the fuse won't do shit unless the amperage goes above 300a
Syphlyns 2000 F150 4.6L V8
H/U: Kendwood KDC-X898
Speakers: 4 x Alpine SPR-68 Speakers
4 Channel Amp: Alpine PDX-F4
Sub: Sundown Zv4 12
Sub Amp: Sundown SAZ-2000D
Box: 2.75 Cu Ft @ 31Hz
Alternator: Mechman 250A elite series
Wiring: All KnuKoncepz 0 gauge OFC + KnuKonceptz Krystal RCAs
What I fail to understand is why anyone would argue to NOT put a fuse in. Why anyone would want to put their investment at risk because they "felt" it wasn't necessary.
I fuse, I fuse everything that comes off of a battery + post, you will see negligible loss, if you ever get in a car accident it may save your car from going up in flames, thats the main reason I do it, not that you will save much, but hey if you get trapped inside and that 1/0 decides to go up like a Christmas tree then your gonna become a turkey dinner, I have a 250amp alt about and a 300 amp fuse that is on a 1/0 knu ofc run, then I also have a run from my alt + post to the rear going right to the my distribution for the amps in the back, which is fused back there, mainly cause I usually run a battery back there
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
Like Broke Audio said, fuse slightly higher than your alts output. Given that most of the alt to batt runs are short you aren't fusing as much for short circuit protection, you are more fusing against overcharging. I would rather replace my alt and a fuse than an alt a fuse and an ECU.
What if my truck is onyl demanding 100a of current and the voltage spikes higher? The fuse won't pop before the voltage gets too high...maybe I'm missing something
Sub: Sundown Zv4 12
fuse it. put a 60 amp in. if that blows right away put a 80, then 100 then 120 or 150 or whatever's next......lol
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
So stop worrying about that. If it can't be protected then it can't be. I don't know enough about how that works to say one way or another.
but why would you want a live wire without a fuse?? the other end of that wire is attached to a battery. fuse that shit man.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
It's a 240a alt, going to need a 300a fuse.
EDIT: Is it normal for my mechman alt to faintly "click" when I rotate the pulley clockwise? The pulley is pointed towards me.
Sub: Sundown Zv4 12
oh, I thought you were asking.
Either way you question has been answered so this thread needs to get locked before it derails for the 10th time, lol
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
  • Who's Online   0 Members, 0 Anonymous, 684 Guests (See full list)
