5 channel amp to run my entire system
85buickrivi
Hello everyone im putting together a system for my mini truck i currently have (2) 12 MB Quart RLP304 shallow mount subs im looking to run the MB Quart Onyx OA1100.5, subs say there 300 RMS each, This amp says subs 2 ohms @ 500 x1 , question #1 is would this amp be stable 2 be ran at 1 ohm and would it push those (2) 12s?????
Edit
also would it be enough power to run them both?
i just would like to run 1 amp for my whole system due to limited space (mini truck and its single cab)
http://www.sonicelectronix.com/item_67855_MB-Quart-OA1100.5.html
http://www.sonicelectronix.com/item_19606_MB-Quart-RLP-304.html
I honestly wouldn't trust that amp to handle 1 ohm on a substage.
It would be a bit more pricey, but a lot more reliable, maybe even a smaller foot print, to run say a Rockford PBR500x1 for the subs and a PBR300x4 for the components.
Check out memphis belle.. They have a 5 channel amp with a dedicated sub channel and 4 channel.. I use one and its great
Team MaxRetribution
Si Vis Pacem Parabellum
What's the budget here?
The two mentioned above are great. For a lower budget, this Soundstream looks pretty decent: http://www.sonicelectronix.com/item_79512_Soundstream-TA5.1250.html
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
umm really dont have a budget just but if i was to say 3 to 400 range. I wanted to keep all the same stuff i know its not high quality stuff just need a lil bump in my mini truck tired of running around with just the highs screaming i heard of the memphis belle might look into that, also would this work, and how good would it be? if i was to run these 2 amps
this amp for the subs ran at 1 ohm
http://www.sonicelectronix.com/item_67858_MB-Quart-OA750.1.
and this amp for the highs (4) powerbass 4xl 6.5 i would bridge the amp to two channels 2 on each channel bridged
http://www.sonicelectronix.com/item_67853_MB-Quart-OA800.4.html
That MB Quart amp isn't even CEA compliant... so, it's very likely those RMS ratings are exaggerated.
I'd suggest this AMP:
http://www.sonicelectronix.com/item_40253_NVX-JAD900.5.html?SearchClickout[query_id]=43814713&SearchClickout[ignore]=1
Clean power... 2 OHM minimum on the sub output though.
If you really don't care that much and you just want something cheap and works... Just get a Jensen 760.4
http://www.amazon.com/Jensen-Power-760-Car-Amplifier/dp/B00GOFX958/ref=sr_1_12?s=electronics&ie=UTF8&qid=1411963683&sr=1-12&keywords=Jensen+amp
and some cheap mono block amp... It's going to be like $120+ for a 1 OHM capable amp that is brand new... Why does it have to be 1 OHM?
Should be able to get both PBR amp for around $400. Sound little amps, I had a PBR300x4 new lying around for a couple yrs and didn't use because I was building a all Power series build so I installed it in my brothers Ranger pushing 4 Punch 683s and they got loud and sounded great for 6x8s.
http://www.zukiaudio.net/index.html
Very under rated, so do not rely on the posted wattages.
Just a question here bc it doesn't make any sense to me. Idc if their goods amps, prolly are w.e
But isnt that just weird to rate an amp like 10w x 1 channel at 8 ohm?? Like lets say its does ohhh idk 300w at 1 ohm..
Thats like not even in the same universe as 8w though.. forget very, thats like not even remotely close out of this world who the heck typed that how many pushups can chuck norris really do underrated.
Lol I just was like eh whaaaaa?
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
They have a mono rated at 10w x 1 at 8ohms but it has like 5 25a fuses...
My input tonthe thread otherwise is / are those soundigital nano amps..
Setup:
Xs D3400/ Xs XP3000
  • Who's Online   0 Members, 0 Anonymous, 993 Guests (See full list)
