5-6k recommended batt and alt
the biggest alt is not always the answer.. it will also depends how you drive your car. the higher the amperage the smaller the pulley. i got a 350a thinking it would be bad ass. a few high rpm runs and alt is making grinding noises
2 runs is more than enough. 3 batteries minimum 4 is best
Stop confusing the issue with facts and actual testing. Geez man :)
Its getting ridiculous because everyone is making assumptions with out knowing anything.
Who here knows the subs, amps, speakers and vehicle in question?
For all we know he could be looking at running boss or Pyle with 2 12s wired at 2ohms. Equipment only able to make a full 1k rms with less then 120amps of draw on music.
Or
A true 5k amp with 2 15s wired at .5ohms that wants to pull 200-250amps on music.
Maybe its built for comps and only needs enough power for 3-4 5sec burps.
Maybe its a 4banger that can't fit more then a 175amp alt and likes to charge at 13.5v hot.
No one knows yet...
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Dumb phone
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
My 200a alt did 13.5-6 hot. So I got an avbm, problem solved
Electricity takes the path of least resistance.
More runs more options less resistance
Any street guy will tell you that. That's why you see street guys with 10 runs to a single battery and amp
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   1 Member, 0 Anonymous, 2341 Guests (See full list)
