Because you had to ask.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Never run below manufacturer's ratings, that's always my advice.
General consensus about .5 is "if you have to ask, don't do it."
My Channel on YouTube. Check it out for cinematic-style Car Audio videos.
https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ
New 2014 Scion TC 4th Wall Build
https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
No for several reasons. First your electrical is not stout enough. That amp alone can pull more current than your alternator can put out. Also the battery that you are running is too small. On top of that you aren't going to see that much of a difference dropping down to .5 ohms for daily. If you were a competitor and just wanted to burp at .5 ohms then I'd say that you'd be fine for that but not music. A couple hundred extra watts isn't going to be worth frying your amp over. You should get the correct ohm subs and then try again. I would suggest dual 1's so you can run the amp at 1 ohm where it is meant to be operated at.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
146.4 sealed on the dash at 37hz
2001 Focus ZX3: RETIRED
Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore Champion
Highest NSPL Scores to date:
154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz
155.2db unofficial on dash at 43hz
Post a video and pics after your fry stuff. Always good for a laugh :)
Experience is the best teacher sometimes, that and having to empty your wallet for new stuff.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Can you? hell yeah. Should you? Nope.
1997 subaru legacy outback
Four 15's in a almost wall
Rockford Fosgate t2500-1bdcp
Rockford Fosgate T400-4 on tweets
Rockford Fosgate T400-4 on highs
Rockford Fosgate T400-2 on midrange
Rockford Fosgate T400-2 on midbass
Optima Yellow top batteries
270A Singer alt (working on a bracket for a second)
Lots of Second Skin
  • Who's Online   0 Members, 0 Anonymous, 755 Guests (See full list)
