So... you like big subwoofers?
This was posted on the B2 Facebook page earlier.
B2 Audio X2C subs dam near done
Custom designed B2 Basket
Triple Stacked 25 x 300 mm slugs (thats about 1" x 11.8")
5" coils
available in 15" and 18"
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Pretty, yes. Expensive? Surely. I Wonder how much spider is left after a 5" coil and former rape the middle of it....
Very good point on the spider issue. The baskets are custom tooled, so I'm sure its similar to a 3inch coil and a 9.25 spider. Or a 4inch coil to a 10inch spider as far as ratio goes.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
I didn't even notice that it was 15" and 18" only. Play on, I'm dumb. I would be a wee bit concerned on a 12" basket, custom or not.
Well the slugs alone are almost 11.8 inches wide. Even if they could make it on a 12inch frame with out spider issues, try mounting that sucker! 130lbs hanging off a 12 inch pivot point, not to mention it wouldn't even fit in most 12 inch sub cut outs by about a half an inch. Lol
Even a 15 with this motor would be a monster.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
interesting
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
  • Who's Online   0 Members, 0 Anonymous, 4888 Guests (See full list)
