Quick trunk build log. SOM here i come
I heard creamy sriracha helps strengthen the sub and adds upwards of 2-5 dBs
Any truth to this? I'm new to car audio and need to find out if putting sriracha sauce on my 12in Kicker Comps in a prefab ported box tuned to 96Hz will make them louder
Please let me know ASAP
Yes but only when added to the amp too. And don't forget to put polyfill in the port. don't want port noise.
Like on top of the amp? Or do I have to apply it to the terminals and take the cover off and put some inside? How much? Does brand matter or are they pretty much the same?
I don't mind paying more if it's worth it.
My budget is $4.09
My amp is a Boss 18500watt AB monoblock dual channel with gain and bass boost knobs stuck on highest level for max output
Normally it would be strictly internal but since it's boss every inch must be covered thoroughly.
Your budget is way higher than needed. You may consider buying a second amp to double the power
Thanks for all your help. I also decided to place the amp inside one of the port walls for optimal cooling.
I will be using ranch dressing to bond it to the particle board wall and toothpicks even though they are not needed because ranch holds so well.
A second amp sounds good, but I think I'm gonna get 7 batteries on my stock alternator.
When playing full tilt I am seeing as low as 2.4 Volts. I know most people don't get worried till around 1.1 Volts but I just want stout electrical.
6.5 Volt demos for the win.
The L@zy Hoe
2005 Chevy Tahoe
2,500 Watts of Highs/Mids
4 10 midrange
4 6.5 midwoofers
4 Tweeters
6 Supertweeters
2 Lithium 80AH Batteries
24K Watts
4 Custom 18s
Quad alt setup Rebuilt 250amp and 3 370s
Interior work by Lone Star Auto Works
The Build Log
Like Loud Bass? Click Here!
On 12/5/2014 at 8:06 PM, juan777 said:
See yall there, I'll be the drunk Mexican with aviators on.
On 12/6/2014 at 10:32 PM, boom50cal said:
I did see Juan LMFAO! He REALLY WAS the drunk mexican with Aviators on!
Seems like Rolex is bored... Im in for him to bust someones balls today..
:peepwall:
Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born.
My penis is bigger than your penis
I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
As long as you're at least 2 volts and your subs are wired to at least 37 ohms you're good
1998 chevy blazer 4 door
stock alt 105a
Battery: Autocraft Gold 75-3
Big Three in Sky High Car Audio 4ga
subs: rockford p2 12's (soon to be sundown SA 12's)
Sundown SAZ-1200d on the subs
Mids and Highs: Infinity kappa 6.5 mid in front doors and tweets in Dash
sae 50.4 for mids and highs
SMD OM-1 on the subs
adjustable ports.
working through some port noise issues when opened up all the way for hair tricking
for daily I go sealed. I'm big into metal and classical.
when I burp or let the bass drop I go WOB (wide open bag)
Rolex you sicken me.
Just let me finish my pie
~ Juice
funky pups are better....
but you get my vote for SOM!
:lol:
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
my subs are tuned to pastrami with pickles in the corners held together with Dijon.
Some people use toothpicks to hold it together but if you use the right condiments toothpicks are worthless.
Stick to a name brands like Subways, Jimmy Johns or even Penn Station or Quiznos. they all use top notch stuff
40 hz and up the rest is wasted information
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
