Question about setting AMP gain with multimeter
hutt132
I set my AMP's gain with a multimeter while playing a 50Hz test tone. I set it to 44V since it is a 1k watt amp wired at 2ohms, but I noticed when I played a 33Hz test tone the voltage was in the 60V range. The equalizer is flat. Is this normal, or should I set the gain to 44V on the tone that produces the most voltage?
I know using a multimeter isn't the best method. Please just answer the question instead of recommending a DD1 or osciloscope.
All you're doing is guessing so it's really hard to answer that question
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Where does your deck distort at?
26
How exactly do you know that?
26
How do you know?
And think about your answer b4 you hit post because it will be the difference between getting real responses and having your ass handed to you. You already came off like a dick in your 1st post and I got the day off
Rolex you sicken me.
Just let me finish my pie
~ Juice
You can't accurately set gains with a multimeter as it cannot detect clipping. It is similar to why you can't use a dmm and a clamp meter to find the wattage output on an amplifier; there are just some things these meters just do not take into account like power factor. (Forgive my incorrect op, I was eating and thinking at the same time lol)
To try and answer your question the voltage difference you see IS normal. There are a lot of reasons why setting your gains with a DMM is not an accurate way of to do it. It's like trying to use a phillips head screw driver to remove a head bolt.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   1 Member, 0 Anonymous, 738 Guests (See full list)
