Hey everyone. I've made quite a few threads (on different topics) recently, but this should be the last one for awhile!
I may be purchasing a VM-1 to replace my Stinger. However I am concerned on the brightness of the blue LEDs at night. I have done quite a bit of searching as I figured the answer would be easy to find, but didnt come up with anything. If the answer is out there and I didnt find it, I apologize.
My current Stinger is blue and unbearable at night, I have to swap the blue faceplate with a separate red one I bought, for me to not be blinded. And am hoping that the VM-1 wont do the same. Any opinions?
Also, I currently have extended my voltmeter's wires running all the way back to my battery in the back, and therefor had to use the trusty adjustment screw to get an accurate reading. WIll the VM-1 still be accurate with the wires extended 10+ feet?
Thanks in advance.
The VM-1 is acurate. There is actual voltage drop accross wire so the further from the source you locate any voltage meter, the more drop you will see. It's not a fault of the meter.
What alot of people do to tone down the brightness is to mount them behind a piece of smoked lexan. Pretty easy to do yourself imo.
I sold mine cuz it was so bright....then I was told you could adjust the brightness. Never researched it to find out if that was true. But mine was BRIGHT.
01 Suburban Z71 - 5.3L - Black - 6" Lift on 35's - Pioneer H/U - Kicker Mids, 8" Polk sub.
Past rides-
07 Avalanche - Sunburst Orange - 4/6 Drop - Pioneer AVH-X5600 - 2/0 Royal Excelene - T/M fuse blocks - Stock and Singer 350 Alts - 4 Kinetik 1800 - Crecsendo BC5500 & S800.4 amps - 2 Tantric HDD 18's.- RE XXX 6.5 comps
01 Grand Vitara - V6 - 4x4 - Pioneer H/U - Incriminator 6.5 Comps - SSA XCON 18 - Skar 1500.1 & 84.4 amps - Singer 160 Alternator - Optima Yellow top..
you cannot adjust the brightness....and if a VM-1 is too bright for you you must have really sensitive eyes. Even mounted in the gauge cluster right in my face they don't seem to bright at all. But then again, cars come with dash dimmer's for people that like their lights dim. Not me. The O.P. must have really sensitive eye's too because i have never thought of my old Stingers as bright either, and i have had a lot of them in my past.
the OM-1 probably gets brighter than them all due to how many LED's actually illuminate while playing the system at high volumes. But a VM-1 is one little blue LED. Not a big deal at all.
Follow my Tweet (Twitter)
The vm-1 isn't to bright imo. If I'm tired and had a king day then sometimes it will seem to bright.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
OM-1 is kinda bright (but I love it) got it going behind a 1/8 piece of smoked plexi.
1998 chevy blazer 4 door
stock alt 105a
Battery: Autocraft Gold 75-3
Big Three in Sky High Car Audio 4ga
subs: rockford p2 12's (soon to be sundown SA 12's)
Sundown SAZ-1200d on the subs
Mids and Highs: Infinity kappa 6.5 mid in front doors and tweets in Dash
sae 50.4 for mids and highs
SMD OM-1 on the subs
VM-1 is not too bright.
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
I just mounted my OM-1's low so they aren't a distraction when driving. For me it isn't the brightness so much, it's that it changes alot with the music but I like them bright.
