expanding foam in the heat?
some wise ppl told me to throw the can in the freezer for a bit, and/or spray at night.
I'll try this since kyle said to cool it down also. And ill do it in the afternoon.
i thought this was something that was already set up. Nevermind, i will leave now.
haha
Have duct tape at hand. Spray it in then tape up the hole. Move to the next one and repeat.
Also already at at.night when its cooler or early morning.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I cover as many openings as possible, but if air doesn't get to it so good then it takes a long time to dry also. I used two cans the other day when it was 40-50 outside and shook the shit out of the cans first, I had bought the cans last summer and never used them. They sprayed out awesome (foam) and basically set up right in place where I sprayed them out of the can. Probably the best experience i have had with the stuff honestly. I have about 6 more cans that are 1 year old like that. I sprayed multiple cans in the summer before and that shit ran and ran, I thought it was because i did so much at once but it might have been the heat. These are my own experiences so I don't really know. I normally spray the shit into places I can't see so meh, no clue
hope this helps
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
thanks, I was just gonna tape and then spray through other holes but i like the idea of spraying and then taping over it.
hope this helps
thanks, At least now i know it's not the cans i have because mine are about a yr old also.
I read misting water also helps cure it faster. It helped me out a lot when i did mine.
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
Misting water on the area before it gets foamed or misting water on the foam/area after I foam?
Cold can or not, if your vehicle is sitting in the sun and the metal is hot. It will not expand properly.
