How many ohms will an amp read without subs hooked up?
ModestDb
Like the title says...
If I have a 1 ohm stable mono-block amp hooked up but check across the speaker terminals without anything hooked up to them...what ohm should I see?
Or more specifically...is there any reason I should be getting 12 ohms using a fluke meter?
When I play music with the subs hooked up, there is no voltage across the terminals at all either.
Blown amp?
BTW...the RCA's are good because I can swap my friends amp in and it plays. I would check his amps ohm load but he's at work right now.
4 American Bass VFL 8" at 0.5 ohm
Soundstream Tarantula 3000.1D at 0.5 ohm
32 hz ported box designed by Mark at Car Audio Fabrications
XS D1200 secondary with Stinger isolator
most likely your amp is shot.
amps dont put out "ohms".
the ohm at which the amp plays at is determined by your speakers/woofers, and what the impedance of the voice coils are, and how they are wired.
Well my amp is showing 12 ohms across the terminals and it doesn't change when I hook my 2ohm dvc Memphis Mojo up to the terminals.
Ohms is the load being drawn by your drivers.
Without a load, the amp should not give you a reading of any kind.
Your amp has been shorted out somewhere ...
I had this same model amp before (Soundstream Rubicon 2500) on the same Mojo and it's still wired 1 ohm. I had someone buy my amp from me a while back and I just bought a replacement from a store on e-bay. It was advertised as new but it arrived yesterday and is clearly a refurbished one. A poorly refurbished one at that.
*The positive and negative terminals have signs of hot arcing
*The clear plastic around the positive terminal is lightly browned
*There's a scratch in the painted blue surface
*One of the mounting feet has clearly been broken off and glued back on
*All 4 mounting feet have witness marks where screws have been in them before
*The gain, bass boost, lpf and ssf knobs all have twist marks in the flat head screw driver slots, as if someone tried to turn them too far
*The power light comes on and the protection light is off but when the fan kicked on, I immediately smelled a whiff of smoke. Never saw any smoke just smelled it
This isn't my first rodeo so I didn't hook it up wrong. I went back over my B+, ground and remote wire just to be sure I'm not mistaken. Besides, like I said my friends amp hooked up in its place without issue.
Take pictures as proof and file a claim to get your money back.
This.
Not saying you are wrong, but the amount of times on this forum that people have said that..... and then ended up wrong.... is quite a bit.
"this isn't my first rodeo" doesn't tell us anything.
Tells us he's a cowboy
:peepwall:
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Just finished taking pictures. I emailed that e-bay store and they asked that I send it back to them and let them get me one in good shape. I asked if they were refurbished but they didn't directly answer my question. Only that they would have one of their "technicians" look at the one I send them back. Should I send it back or should I appeal to e-bay complaints?
  • Who's Online   1 Member, 0 Anonymous, 738 Guests (See full list)
