hidden from sight port????
dsw422
the speaker grill in this picture off to the side.. the Camaro im building for has no speaker there..
and im tring to stay away from sealed.. ( last resort!!)
and I cant turn the tube inside for proper length due to the size of the woofer.. takes up any space that the port would need to make the turn..
and don't want to cut a hole in the plastic panels since this s a show car..
2014 Ford Focus SE Sedan
Factory Sony 10 Speaker Sound System
1994 Ford Bronco
Dual head unit (i kno)
Sony door speakers
Kenwood Rear Speakers
Custom Center console in the works. will house an NVX NSW10"
https://m.facebook.com/WinnsCustomCarAudio/
Why is sealed a last resort?
Guarantee you it will sound better than porting it to the inside of the body.
the guy im building for wants ported.. so that's y.. you think sealed will still hit pretty hard?? sub is a Cerwin vega Stroker 102.. its got 29mm of xmax!!
1994 Ford Bronco
Sony door speakers
Hiding ports behind panels is asking for trouble. If its anything the 2 12 pic above, either port forward or sealed. Unless you tube it all the way to that speaker opening or w.e and outlet straight out of there.
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
The distance between the port and what it's going to unload off of has to be the size of the opening of the port.
For example of you have a 4 in. aero port it has to be at least 4 in. from the panel it's going to unload off of, make sense?
It has to be able to unload off something. To me it sounds like you're trying to block it off.
Team Bass-Hz
the port wouldn't be blocked it would be blowing into the area behind the panel...
and the pic above with the 2 12s follows a different line.. I am actually following the body panel lines
1994 Ford Bronco
Sony door speakers
Either port it out the top, or go sealed. Don't know why so many people are afraid of sealed, just choose the right drivers and you'll be happy.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
That's going to be a long port to get anywhere near useable. Even if it's behind a panel it's not going to be much better than sealed. Why not a slot port?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
The panel will only act as an extension of the port and the sound will only resonate in there and then bottle neck out of that speaker cutout. As I said before. It's not going to play the way you think it will. Output frequency into the cabin will change and your output won't be as loud as it should be. Change your design or change the port enough to port it through that speaker cutout to retain frequency desired
  • Who's Online   0 Members, 0 Anonymous, 3125 Guests (See full list)
