Foam tape on the edges of panels if that's your issue (still able to remain hidden from sight). Didn't know second skin had sludge.
It's called Spectrum and Spectrum Sludge
Gotcha.
You're aiming for a 150+ vehicle, you might quiet it down but you Will not prevent it.
"rattles" as mentioned are just two or more things hitting each other. All you need to do to remedy that is to decouple them.
Closed cell foam (CCF) is commonly used for this. Butyl rope is also awesome at it if you can narrow it down to specific spots.
Was going to mention butyl rope but I believe it was mentioned in the reading I provided. That is, if he went there abs read it. Decoupling is the key, no matter how you do it. I didn't even get into the MLV discussion with him ;)
Doesn't second skin make some too?
We make a lot of products taht can help you, our liquid sound deadener called Spectrum may be what you are looking for......check it out here
I have used Speaker Box Carpet "Felt" stuff for between Trim Panels etc and Dabs of Clear Silicone right on the back of where trim has screw holes so when the screw goes in it will make a Cushion and keep the screws from coming loose but still will come out if needed.
