Okay So i have a 90 Bronco, I just got a new amplifier "My old one did the same thing" so anyways when ever i turn the Key to (On) position the amplifier fade in slowly how it should.
Now when I start my truck, the subs will go "BANG" loudly as the head unit turns on after starting the engine.
My Amplifier is a Power Bass 600.2; also yes it's all wired correctly "I'm a freak when it comes to making things look good and connecting it right, not half ass shit" anyways Remote is connected to the (Blue Remote Out) A.K.A Antenna Signal) same thing.
But this only happens when I start my Truck. I have grounds every where "Also lets Mind You that all the ground points are Shiny Wire brushed Ground Points" So I know for a fact I have great Grounds EVERYWHERE even for the head unit I ran it's own ground to Bare Unpainted Metal.
If this helps I have...
Pioneer DEH-150MP Head Unit
Power Bass 600.2 Bridged Running Two 12" Kicker Comps.
Amplifier power Wire is 4 Gauge & the Remote Wire is a 18 Gauge
All the Wiring Kit is a good Quality kit.
Remote wire is blue with white stripe. Not blue. You have turn on pop
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Found The issue!
I took some Stripped Wire and wrapped it around the RCA Jack Output Jacks and unscrewed the nearest screw then tighten the screw down over the wire.
It was a bad RCA Ground from the Head unit it's self I guess it's a "Pioneer Thing" they are known for their RCA Jacks not being grounded properly internally frm what i have found out.
I Wish I could figure out how to ad photo's.
no. pioneer is fine. it's only when people unplug and plug in rcas when the headunit is on. causing a very tiny "pico" fuse to blow, which is what probably caused your issue
  • Who's Online   1 Member, 0 Anonymous, 397 Guests (See full list)
