Subsonic Filter Pros and Cons
All pro and no cons unless you like destroying subs.
Not using it would destroy subs? Lol
Do you even know what it does?
No, you just turn everything to the right. It'll be fine
if you feel that the subsonic filter is a bad thing then you need to tune your enclosure to a lower frequency because playing much lower than the port tune causes your sub to unload and lose control and burn up.... if you want to play lower then 30hz you need to tune accordingly..... a sub in a 30hz box will not like 22hz waves..... hence why most people set the subsonic at 28hz and tune ports around 32hz ....without a subsonic filter you cant set your lower limits for a safe passband "low cutoff"
If you dont know your systems' limits or dont know the song(s) you're playing, yes.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
