Nightmare Posted December 14, 2015 Report Posted December 14, 2015 Ok so to start off my truck is a quad cab dodge ram i ditched the rear seats. i had 2 crappy 12s from some brand i never heard of and 2 15inch rockford p3's all hooked up to a 2000rms hifonics amp at 1ohm. I wanted deeper bass so i ditched the 12s and ran the 15s at .5 0hm which ended up blowing 1 of my 15s now im running 1 15 in a custom horn type enclosure (like you see at rock concerts) just to experiment. Its only a matter of time before that one blows aswell considering im pushing nearly 4x rated rms into it.so to get the bass that im craving ive determined that i should just build a wall and shove as many subs into it as possible but at the same time i dont want to spend more then 1k on this. An important note here i dont compete in spl competitions nor do i compare how loud my system is to anyone elses. This is for my own enjoyment with music not one note burps. Now this is what i was thinking of getting which is in the budget but im basically just looking for reassurance that this will do what im looking for (entire car flex and insane chest pounding and really loud 150-160db musical) 8x earthquake tnt 12 inch http://www.sonicelectronix.com/item_38118_Earthquake-Sound-TNT-12DVC.html 2x this box stacked and bolted together https://www.atrendusa.com/12-four-hole-vented And another 2k rms amp from hifonics cant find the exact one i own anymore but they have similar ones Wired at .5 0hms should give about 500+watts at full tilt to each speaker with 4 speakers per amp. And yes i already have a mechman 250amp alt and 2 runs of 0 gauge. No battery bank though i dont play music with the truck off. Am i on the right track here for a budget wall? Or am i just going to end up disappointed and try overpowering them and blowing these up aswell?
Broke_Audio_Addict Posted December 14, 2015 Report Posted December 14, 2015 That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
audiofanaticz Posted December 14, 2015 Report Posted December 14, 2015 Wall for sure Vote for trump he will get you the wall!
LT.Smoke Posted December 14, 2015 Report Posted December 14, 2015 Ok so to start off my truck is a quad cab dodge ram i ditched the rear seats. i had 2 crappy 12s from some brand i never heard of and 2 15inch rockford p3's all hooked up to a 2000rms hifonics amp at 1ohm. I wanted deeper bass so i ditched the 12s and ran the 15s at .5 0hm which ended up blowing 1 of my 15s now im running 1 15 in a custom horn type enclosure (like you see at rock concerts) just to experiment. Its only a matter of time before that one blows aswell considering im pushing nearly 4x rated rms into it.so to get the bass that im craving ive determined that i should just build a wall and shove as many subs into it as possible but at the same time i dont want to spend more then 1k on this. An important note here i dont compete in spl competitions nor do i compare how loud my system is to anyone elses. This is for my own enjoyment with music not one note burps. Now this is what i was thinking of getting which is in the budget but im basically just looking for reassurance that this will do what im looking for (entire car flex and insane chest pounding and really loud 150-160db musical) 8x earthquake tnt 12 inch http://www.sonicelectronix.com/item_38118_Earthquake-Sound-TNT-12DVC.html 2x this box stacked and bolted together https://www.atrendusa.com/12-four-hole-vented And another 2k rms amp from hifonics cant find the exact one i own anymore but they have similar ones Wired at .5 0hms should give about 500+watts at full tilt to each speaker with 4 speakers per amp. And yes i already have a mechman 250amp alt and 2 runs of 0 gauge. No battery bank though i dont play music with the truck off. Am i on the right track here for a budget wall? Or am i just going to end up disappointed and try overpowering them and blowing these up aswell? I have not built a wall before but I know there are several skilled individuals on SMD that would be able to point you in the right direction... DITCH the 2 boxes bolted together and build the wall the right way it will sound much better and be more reliable... Also battery banks are NOT just for playing with the vehicle off they're for providing extra power on demand when it's needed so that's another good investment... My advice is to spend a little time searching SMD and I bet you'll find the help/info you desire Team MaxRetribution Si Vis Pacem Parabellum Id rather be judged by 12 than carried by 6 Bowhunting- Life Begins and Ends at Full Draw Bowhunting Team Fatal Trajectory Hunt Team http://www.stevemeadedesigns.com/board/topic/49335-sick96vtecaccords-t-line-build/?hl=sick96vtecaccord << Accord Build http://www.stevemeadedesigns.com/board/topic/68498-smokedout08impalas-tline-build/?hl=+sick96vtecaccord << Impala T-line build Rebassed.com for all your music needs 👌
bman8891 Posted December 14, 2015 Report Posted December 14, 2015 Good luck man. I dont see you doing 150-160 musical with that equipment but Im sure it will be loud. I would suggest doing a TON of research before you commit to your subs and amp(s) and wall design.
Nightmare Posted December 14, 2015 Author Report Posted December 14, 2015 :/ well damn i was really trying to avoid the battery bank as if it was a plague or something lol. I know ive heard alot of people say its to prevent vdrop ect its just i have no idea where i would put it.im working with a pretty limited space . i wont put anything in the bed of the truck. Everything has to fit in the cab. And be removable ( if i ever decide to sell the truck its a 2011 in absolute mint show room quality condition) so having a true wall fiberglassed and sealed off is out of the question. So with all of that in mind what would you suggest as the best route for me? I already tried the simple route of just throwing money at it and hoping it works which didnt just lead to me overpowering my subs and cooking them
Massivespl Posted December 14, 2015 Report Posted December 14, 2015 That box u posted has enough room for 10" at 1.25cubes per section... c-pillar flat wall 157.11db on music 2 crossfire 8k 4 NSV3 18s 4 crescendo 10s 4 Rockford pro 6.5s Quad excessive amperage 350alts 4 juicebox 3100s
bighossf150 Posted December 14, 2015 Report Posted December 14, 2015 If you honestly want to do a 150-160 musically get ready to spend some money, I had around $10k is my set up that did a 158. Not gonna get there with cheap subs and hifonics amps. Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
Jman9112 Posted December 14, 2015 Report Posted December 14, 2015 2 really nice 15s in a proper box will rattle that truck apart. My shitty 2 12s bounce shit around on 1k. Just grab some zv4s or some hccas or something similar, run another hifi, one to each and tune low. Say like 8 cubes at 30hz Ballin' on a budget.
n8ball2013 Posted December 14, 2015 Report Posted December 14, 2015 There is no such thing as a budget wall. There is this which I wasn't even sure if I should respond to or not. And then there is doing a wall. This isn't even a wall. Hell im not even sure what is going on. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
