dual alternator in my honda questions
With my 2.2l second alt full tilt stalls the engine. Engineered a bracket with some trial and error. Deleted AC to make room. Heat shielded stuff. It adds up quick. I would do it again but if you aren't the hands on mechanical type stick with a good single H.O. in the stock location.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
i also say you should be fine with an ho alt, no need for two.. just make sure all you connections are fine and try to find a way to bypass the charging system
i run dual alt set up.. 270 & 370 amp's in chevy malibu 3.5L 6 cylinder... when the bass hits you will definitely feel when the alts are spinning and drag the motor down.
on a 25 mile speed limit driving around on 2,000 rpms i drop between 1000-1500 rpms depends on the draw. i really have to be around 2500-3000 rpms going full tilt on radio to keep it steady
Again your over dorking this. Put a decent aftermarket in and run a true 6K
Speaking from experience... This x10000
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Like others have said, you don't need dual alts. Waste of time and money. Get an alt from reputable company (there are only two out there I would give my money to), get an agm batt that fits your stock size under the hood and toss a group 31 size batt in the trunk, and you will be more than fine. If youre having problems with the ecm, you can bypass that if you really wanted to but not really needed with what you're running. If you want good idle voltage and idle low, don't be fooled by "get the biggest alt you can fit".
Good luck
Singer Alternators
Team Asshole
#anothershittysingerbuild
  • Who's Online   2 Members, 0 Anonymous, 1772 Guests (See full list)
