Rockville M-4 At .5 ohm (no joke)
ShadeTreeMechanic
how does one tune a sealed box?
I was wondering the same thing
c-pillar flat wall 157.11db on music
2 crossfire 8k
4 NSV3 18s
4 crescendo 10s
4 Rockford pro 6.5s
Quad excessive amperage 350alts
4 juicebox 3100s
That's that Rockville math.
Nav-TV Zen V Audio Interface
AudioControl DM-608
(2) Stevens Audio Neo-Comp Full-Size Horns
(4) Faital Pro 6PR160 6.5"
AudioControl LC-6.1200
(1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz
Ampere Audio AA3800.1
Odyssey ODP-AGM48 Battery (Starting)
Odyssey ODX-AGM31 Battery (Trunk)
Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
Do different size sealed boxes perform differently? Do different size ports perform differently? Hmmmm.
Still learning but have started gathering.
How do you tune a sealed box? Can't cause it has a flat response.
You guys are a blast!! I almost spit my coffee through my nose!!
Really though the sealed box is tuned by its volume. Pick your box Q (Qb) maybe .7 for flat response and nice roll off or higher if you want a big bump. Plug and chug the numbers in the equations. You will get the box volume (Vb) for your selected Q, then you get your resonant frequency (Fb) which is what your box is tuned to, then you get your 3db down point (F3) on your roll off. So this is how it can be tuned to 59Hz with a F3 of 44Hz.
Because this is how we figured out how big to make the box to begin with right?
Thanks everyone for your input!
Pioneer 80PRS
Knowledge bomb deployed.
