rocking.that.eclipse Posted February 17, 2016 Report Posted February 17, 2016 So I found this nice little approximation for resonance of a single sub in a sealed box. It is: Fs* SQRT[(Vas/Vb)+1) So i'm wondering how do you take this single approximation and modify it to fit for more subs. I know that resonance will change as you add subs and you increase sealed side as long as you don't make each sub in its own box (ie sealed box with 6 12s all common chamber will have lower resonance than 6 seperate sealed boxes for said 12's) Any help or insight would be awesome
hoit Posted February 17, 2016 Report Posted February 17, 2016 ...following for knowledge... 2007 Chevy Aveo Ls sedan 2 Sundown Xv2 on scv4k @ .5 ohm 2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm Big Three, Three runs 1/0 power from front to back, 1 ground front to back Two runs ground from rear bank to chassis XS power d3100 upfront, 3 Odyssey 2150s in bank Singer 220 amp alt
lutkeveld Posted February 17, 2016 Report Posted February 17, 2016 AFAIK box resonance frequency doesn't change when using 'n' subs in a box that is 'n' times as large as a single box. My WinISD sims confirm this.
rocking.that.eclipse Posted February 18, 2016 Author Report Posted February 18, 2016 AFAIK box resonance frequency doesn't change when using 'n' subs in a box that is 'n' times as large as a single box. My WinISD sims confirm this. So youre saying that a 1 cube box with 1 sub in it will have the same as a 6 cube box with 6 in it
fecupe2001 Posted February 19, 2016 Report Posted February 19, 2016 everything changes when you add more cone area, cheers! I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
Kyblack76 Posted February 19, 2016 Report Posted February 19, 2016 everything changes when you add more cone area, cheers! Lol. This. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
ALPINE408 Posted February 19, 2016 Report Posted February 19, 2016 in for this record breaking system on paper! dont get to caught up in calculations with vehicle variables the only true way to get loud is test test test and test some more Have you ever had your woofers blown?
CstrokerV Posted February 20, 2016 Report Posted February 20, 2016 Alot channges with box size.. my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
