Looks tits. I saw you post a vid of "balancing" stuff. Why would anyone care if the bats aren't dead on? Makes no sense to me. Anyway, looks rad dude.
In short it could be very dangerous to not do so
For example I have 16 3.2v batteries in my setup. Highest voltage they can safely handle is 3.6 per cell
Before balancing my voltage was terrible. Lights would dim, voltage would drop dramatically on every bass note (mind you with only 3500 watts and 360 ah of lithium) and it even affected the car driving
Turns out two of the cells were charging to 4+ volts, 6 were around 3.4, and the remaining 6 were in the dirt at 3.1.
In essence I only had two batteries of capacity until they dropped to 3.4 in which case I now had ten and all 16 only when the voltage dropped to 12.4
I got some passive balancing circuits which holds the batteries at 3.5 each (14v nominal) and I've never seen it drop below 13, even with my now 8000 watts (2 ampere 3800s @ 0.35) and a stock 180 amp alt
Balancing is absolutely necessary
^^and to add to that if he had continued to run those without balancing the low voltage cells would die prematurely. Performance and longevity are optimized with balancing.
Ih8PunkRok- do you have a link to those balancing circuits?
I bought them from a company called ev power in Australia
Cheap little boards with a large resistor in them. Work beautifully
http://www.ev-power.com.au/-Thundersky-Battery-Balancing-System-.html
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Well damn! I just assumed with the high current capability balancing circuits would be outrageously expensive. That's not bad, thank you for the link.
I thought that as well but if you think about how the electricity flows the amperage that goes to your amps doesn't actually pass through the balancers. It goes around them
I could be wrong about that but it makes sense in my head. The internal battery has less resistance than the balancer so the electricity tends to follow that path under load rather than the shorter circuit that has much more resistance
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
I love Jeeps, but I'd be scared as hell to tow that thing with a WJ. I really hope that trailer has brakes on it.
Builds:
^^ this
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
wasn't a good idea towing that thing with that wj on that trailer...
those 3500lb axles were screaming for dear life. that explorer has to weigh atleast 6,000lbs if not more...
oh whale. not my rig I can't criticize.
  • Who's Online   0 Members, 0 Anonymous, 922 Guests (See full list)
