Removing the rubber from around the magnet? Yes or no
I have a pair of JL Audio 15w3v2's. They have serve me well for a few years. I took them out to get ready for a rebuild and noticed the big ass rubber doughnut around the Magnets of the subs.
1. Should I cut the rubber off or leave it on?
2. What are the pros and con's of either choice?
Help a Brotha out.......
Does this smell funny to you? Its your sister :roflmao:
I was thinking that there might be some cooling advantage by removing them........ Discuss
Not really. The magnets don't produce any heat, they just get warmed up from radiant heat coming off the coil. If you burn your coils up with the boots on, you were going to burn them up if the boots were off anyway.
Builds:
If you want the boot off set them face down in the sun for like half hour to get the rubber boot warm and flexible and just peel it off. at the end of the day they are your subs and doing so will have zero impact on performance whatsoever so you just do you.
Its there to protect them from chipping and such. Not "needed", but no advantage to removing.
Disagree.
Many times where removing the rubber boot can be louder by a drastic amount.
On some W3s it wont make a difference, or most 15s in general.
But on 10s and 12s with beefy magnets that are near the size of the sub cutout with the magnet boot on you can gain a lot on the meter usually just due to air pressure being able to move around more freely.
The one eclipse I helped with with 4 dd9512s walled gained something like 1.3db iirc from removing the magnet boots, but it had a decently thick baffle and the magnet structure was partially in the baffle so it really opened up the area around the magnet.
Cool guys, thanks for the info, I'll remove them. Pics to follow as soon as I remember how to post them?????? Help
Disagree.
I remember someone that made a thread about all the things that can be done and hot they effected your loudness, from ac vents to seating position. I always just take mine off
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
