Sleezyk Posted July 5, 2016 Report Share Posted July 5, 2016 Most dbl dins I see have a dumb USB wire hanging off the back..what are you suppose to do with that? have it dangle in your floorboard? I know the LCD takes up a lot of front face but a USB or even a micro USB would fit easily... Is there something I am missing? My "xbox one" had USB on the side and not front like my 360 as well so, I'm half way thinking its a new trend or something... #confused BOSS Audio FTW! Link to comment Share on other sites More sharing options...
Jessica Posted July 5, 2016 Report Share Posted July 5, 2016 Just route it down to a console or cubby spot and run it through there. You may need an extension cord Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
Skullz Posted July 5, 2016 Report Share Posted July 5, 2016 Most face plates have to tilt out to access the cd/dvd drive and a usb sticking out could cause some problems. You can route it to you glove box if you prefer to have it hidden, or just let it hang down to the floor, which i what i do. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
3vil Posted July 5, 2016 Report Share Posted July 5, 2016 Find and either make or trim out a location to house a USB dock, so that when finished it looks like your car came with it from the factory. Link to comment Share on other sites More sharing options...
fosgatefan821 Posted July 5, 2016 Report Share Posted July 5, 2016 Mine is in my glove box. Rather have it there than some stick sticking out of radio. May draw attention or accidental hit and it breaks 2007 Ford Ranger (ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES) K&N Performance Air Intake Massive Audio D2400 Mono Amplifier 2 Custom Built 8" Subwoofers in Ported Enclosure Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed) 4 - Pioneer TS-A6886R 6" X 8" 2 - SMD Heavy Duty Single ANL Fuse Blocks 2- Stinger SPP1200 Dry Cell Batteries JL AUDIO Interconnects 2/0 Gauge Big 3 ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals ILL Customz 1/0 to 4 Gauge Power / Ground Reducers Factory Alternator __________________________________________________________________________________________________________________________________ 2002 Cheverlot Monte Carlo SS - (Deceased) 2 - Rockford Fosgate Power 1501BD 1 - Rockford Fosgate Power 851x Rockford Fosgate Power 6 1/2 Components Rockford Fosgate Power 3 way 6x9 2 - JL Audio W7 13.5" Subwoofers (Sealed) Pioneer AVH-P4400BH In - Dash DVD Player Pioneer AVIC - U250 - Add-on GPS Navigation System Audio Control 6XS 4 Way Crossover / Line Driver Ohio Generator 200 Amp Alternator 3 - Stinger SPP1200 Batteries 1 - Optima D34/78 Battery Link to comment Share on other sites More sharing options...
audiolamb6 Posted July 5, 2016 Report Share Posted July 5, 2016 im with all the others i like it to not be seen and if you have to change them that much you need to get a bigger drive then Link to comment Share on other sites More sharing options...
Quiet Posted July 5, 2016 Report Share Posted July 5, 2016 I love my pio has them in the back. so much cleaner looking than to have it sticking out on front. 2007 Pacifica Rebuild. Less quiet. Still not loud. Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted July 5, 2016 Report Share Posted July 5, 2016 There are lots of double din's with front usb. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted July 5, 2016 Report Share Posted July 5, 2016 I have a thumb nail drive in my front USB. Its so small you can't tell what it is until you pull it out. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
mothra Posted July 5, 2016 Report Share Posted July 5, 2016 JVC 220BT has USB on the front. they are the only reputable brand that does have USB on the front. all the others are Boss, Axxess, etc.... and most of theirs are some sort of micro usb to usb adapter. I still don't understand the point of connecting via USB when BT pretty much is equal too it except for when using Apple CarPlay or Android Auto. if nothing changes, nothing changes You don't know what you don't know, till you don't know Link to comment Share on other sites More sharing options...
