Question on wire for batt banks
So I was thinking about how I would wire up my batts in my car. I could place 4 batts easily in the back of my car, 2 in the extra spare spot, and 1 on either side of the box. Now would I be best to run my power and ground straight to one batt, then from there to another and then to another. Or would I be better off with a pos and negative going to a distro block that each battery connects to. Also, if the one connecting them all in a line would I be better, would connecting the single batts first then the last 2, or the bank of 2 first then the singles and from there to the amps distr block be a better option? Is the power just power, or does setting it up in a specific order have anything to do with how it performs.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Just daisy chain them from battery to battery.
Typically I will hook positive wire up to the first battery and daisy chain it from the first to the last. Then I would hook the negative to the last battery and daisy chain it from the last to the first.
But it really doesnt matter much.
No need to run distribution blocks to go battery to battery.
Well I was refering to the distro block as, I already have them installed, and running wire between batt to batt, would more than likely be the same length if I just ran from batt to ditro. I am just curious if there is any way to wire them up in a parallel way that will make them run better, or as long as it is parallel, no matter how it is made parallel, will it be the same?
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
More connections = more resistance. Wire them directly together and skip the distro block. Is there a reason you included it in the first place?
Singer Alternators
Team Asshole
#anothershittysingerbuild
I woulnd't be adding anymore connection when comparing both connection ways. There would be the same amount of wire if I connected all in a line, or from each bcak to a distro. I have a distro block because at the moment there is no battery in the back. So that is the only way to wire up multiple amps. As well, in the future I might be having anywhere from 4 to 6 amps, so it will probably be easier to go from a distro than a battery.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
With the relatively short cable runs in a car it doesn't matter much as parallel is parallel. Just remember to fuse each positive run between batteries at both ends in case one gets pinched in an accident.
Pioneer 80PRS
I feel like I am bad at explaining things sometimes. Hopefully these pics will help. The main thing here is, 2 batts will sit right next to each other in the spare wheel well and pretty much have less than 1 ft of cable length. Where as I will have a batt on either side of the box totaling 2, that's where most of the length of wire will be between batts. The amps will be mounted on the box, pretty much directly over the batteries, just a few feet away.
This is the distro one I was thinking of.
Then I was looking at these 2 set ups. If the one above is not a good idea, would there be any difference between going to single batts first then ending at the 2 together then to amps, or should the 2 batts together be the start, and end at a single batt.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • Who's Online   0 Members, 0 Anonymous, 998 Guests (See full list)
