baller95 Posted August 16, 2016 Report Posted August 16, 2016 As the title states, is it possible to get a 2 ohm load with TWO 4 ohm DVC subs? How about one 4 ohm DVC and one 2 ohm DVC? If so, how would I wire it? Thanks a lot!
Broke_Audio_Addict Posted August 16, 2016 Report Posted August 16, 2016 No. I do not understand why these question's come up constantly. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
baller95 Posted August 16, 2016 Author Report Posted August 16, 2016 Buddy of mine has an amp that puts out 1100 wrms @ 2 ohms and he has a 4 ohm DVC sub. He needs one more sub but ideally it'd all have to be wired down to 2 ohm to maximize amp output. What's the closest to 2 ohm (no less than 2 ohm) I can get with either setups?
ShadeTreeMechanic Posted August 16, 2016 Report Posted August 16, 2016 Don't mix subs. The lowest without going below 2 would be 4. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
White Lightning Posted August 16, 2016 Report Posted August 16, 2016 Why do you think he needs one more sub ??? Hmm ... kinda curious as to what amplifier that's in question here. Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
3vil Posted August 16, 2016 Report Posted August 16, 2016 Why not get a pair of matching 4ohm dvc subs and wire down to 1ohm?
bcbrassard Posted August 16, 2016 Report Posted August 16, 2016 Why not get a pair of matching 4ohm dvc subs and wire down to 1ohm? I am sure the amp is only 2 ohm stable which is why he is asking.....
3vil Posted August 16, 2016 Report Posted August 16, 2016 Why not get a pair of matching 4ohm dvc subs and wire down to 1ohm?I am sure the amp is only 2 ohm stable which is why he is asking.....How can you be so sure when he hasn't mentioned the amp in question? I'm on mobile, so maybe it's in his sig? Or maybe it was mentioned else where? I TRY not to make assumptions, so I thought asking a simple question might help.Not even trying to be a dick here, just trying get the whole picture of his system, goals, and how we add a community can help.
ShadeTreeMechanic Posted August 16, 2016 Report Posted August 16, 2016 If someone asks a specific question then they get a specific answer. If they wanted an answer that is even more specific, then they keep asking different things and more information is requested of them and the real question and answer come in a roundabout way. I think he got his answer. Its funny how a question thread can sometimes go on for pages from a single post and the op never returns. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
