prodigal_son Posted October 15, 2016 Report Posted October 15, 2016 I'm thinking of using two of these in a sealed box wired in series running 800 watts rms, tuned with the DD-1. I'd like something that sounds good and gets really loud. Car is a Civic Coupe. These are to replace two Infinity 120.9s that I thought sounded really good but did not have the volume that kid is looking for. Thanks for any feedback!
Vice03 Posted October 15, 2016 Report Posted October 15, 2016 Hearing your goals I wonder - why not a ported box with the SA-12s? The next question is - what Ohm load are you going for final? With those subs you could wire to 1 Ohm, which makes providing power quite cheap. Lots of options that will do 1000ish at 1 Ohm.
RainStryke Posted October 16, 2016 Report Posted October 16, 2016 Yeah, you definitely want to look at getting a ported box for the SA-12's. If you don't all ready have a amplifier, I'd recommend looking at something in the 1000-1500w range for a pair of those SA-12's.
Ron36 Posted October 16, 2016 Report Posted October 16, 2016 If u don't have the room for ported sealed will be fine but those subs can handle way more power , I'm runing around 1k per SA-10 in a sealed box and they love it. 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery
prodigal_son Posted October 16, 2016 Author Report Posted October 16, 2016 Thanks for the feedback everyone!Room is a factor when considering sealed vs ported, but a true rookie consideration on my part is wondering if using a ported box will degrade the sound to where it doesn't sound good, just gets loud. Am I being ridiculous? I realize that more than likely I am, but I don't have any experience to rely upon.Here is the amp he has been using for the past year, https://www.pioneerelectronics.com/PUSA/Car/Amplifiers/GM+Digital+Series/GM-D9601 . I'm open to suggestions if there is something a lot better for reasonable money that he should be using.
MrSkippyJ Posted October 16, 2016 Report Posted October 16, 2016 a properly designed ported box will sound really good, no need to worry about that. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
akuma4u Posted October 16, 2016 Report Posted October 16, 2016 im running only one ported on about 1200rms and its enough for me as a Daily... others cant even stand to sit inside while its pumping..
boom50cal Posted October 16, 2016 Report Posted October 16, 2016 If you're looking to stay sealed, check out Sundown's SD line. they are more so for sealed boxes and will like the lower power more. But you can't go wrong with the SA series. Such a versatile driver. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
prodigal_son Posted October 16, 2016 Author Report Posted October 16, 2016 I'm assuming that the ported box will play noticeably louder? SPL with decent SQ is where he wants to be.
Joe X Posted October 17, 2016 Report Posted October 17, 2016 Ported just leaves sealed out of business when it comes to output and low end extension, try the infinitys you have in ported and you'll see.
