nkrell11 Posted March 15, 2017 Report Posted March 15, 2017 3 hours ago, mcanderson0 said: That port is SICKKK man. Damn. Thanks for the input, I was scared to cut too deep. I saw on Wicks' build log that he used a slide-pull miter saw to quickly make a bunch of straight kerfs. My miter is not a slide-pull, so I dont know if I want to cut all those kerfs with a circ saw and a guide, as that was a PITA last time. Im also trying to make a 9.25" diameter kerfed curve, which may not be reasonable. Thanks for the input, though. So just leave a single or maybe two plies? Yeah I'd say 1-1.5 plies when setting depth I usually just use a piece of scrap and get it dialed in to where I can bend it pretty easily. There is math to determine spacing on your cuts, I usually do the math and then test it on a small strip of wood 1-2 inches wide to make sure it will form to the curve that I need. If you have patience you can do it with just a circular saw and no guide, I think I made the port on the table saw though as it was pretty large. I also recommend screwing at strip or two to the back so that your kerf doesn't bend the wrong way and break. It also gives you something to grab and push when you're using a table saw. You'll notice in this picture that the cuts are pretty much all the way through to the veneer but theres no lines on the outside. Whereas in this one my cuts weren't deep enough and you can kind of see the lines. I usually just sand them a little if this happens and it makes them a little less apparent. Current Build: 02 Jeep Grand Cherokee Build (AKA Project Silent Night) Mechman, Neo Slow
Kyblack76 Posted March 15, 2017 Report Posted March 15, 2017 Nice work man. I like it SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
WalledSonic Posted March 16, 2017 Author Report Posted March 16, 2017 On 2/12/2017 at 5:57 PM, mcanderson0 said: Grounded my RCAs. Noise prevention. Separately grounded (middle) So as it turns out, my headlights on my car cause a lot of chassis ground noise. This RCA-ground concept would only (possibly) work if they were grounded to the battery post/bus. Well, I dont have noise now that I removed the RCA ground, so I'll retackle that IF i receive hum/noise/pops in the future AND if I can attribute it to the headunit. So for today, BYE noise: Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
WalledSonic Posted March 16, 2017 Author Report Posted March 16, 2017 Used my miter saw to chop the post to the right angle for the welder: So this 1.5" threaded turnbuckle is absolutely ridiculous. Instead, I ordered the 1" version on McMaster Carr and I'll be returning this 1.5" version next week. Either way, the turnbuckle will sit right about here: Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
jcarter1885 Posted March 16, 2017 Report Posted March 16, 2017 Fucking epic, don't want to call it a stripper pole anymore. Shit looks out of this world and almost overkill, really makes your build stand out. Nav-TV Zen V Audio Interface AudioControl DM-608 (2) Stevens Audio Neo-Comp Full-Size Horns (4) Faital Pro 6PR160 6.5" AudioControl LC-6.1200 (1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz Ampere Audio AA3800.1 Odyssey ODP-AGM48 Battery (Starting) Odyssey ODX-AGM31 Battery (Trunk) Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
WalledSonic Posted March 16, 2017 Author Report Posted March 16, 2017 7 hours ago, jcarter1885 said: Fucking epic, don't want to call it a stripper pole anymore. Shit looks out of this world and almost overkill, really makes your build stand out. Truth... A stripper might get hurt dancing on a pole like this. ? Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
BP1Fanatic Posted March 17, 2017 Report Posted March 17, 2017 Rotflmao! 2011 Ford Crown Vic LX, LActrical 240A alternator, A6 Pro, Orion Cobalt CBT.3500.4, 2 CO652C's, CBT.4500.1, 8 JBL GX1200's in an Isobaric BP4.
Karkov Posted March 18, 2017 Report Posted March 18, 2017 jeez, that turn buckle is WAY bigger than I thought it would be, fucking LOOOVE it dude!!!!! 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
bcbrassard Posted March 18, 2017 Report Posted March 18, 2017 Thats awesome, functionality and Art at the same time. Definitely different man, hats off to ya for the original idea and your application of it.
WalledSonic Posted March 20, 2017 Author Report Posted March 20, 2017 Heres the 1" turnbuckle. Much more manageable. With lockwasher and jam nut This will go here, obv this is much smaller than the 1.5" version shown in a post above Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
