Damaged wire repair
So today I realized the 1/0 I ran under my car was hit with something and the wire is busted. I haven't tested yet but I believe I'm still getting good voltage.
I want to fix it but I'm not sure how. I really don't want to buy a whole new run. It is turning green and has oxidation  all in it so I want to clean it out and wrap it in something. Electrical tape? Idk. Either that or cut it out and replace the section. Which I think to do right would mean cutting about a foot of it out and attaching the new span with two fuses. But I'm not sure.
Also, I know I was asking for it by running it bare but it's tucked away good and didn't think I'd have a problem. Lesson learned!
Thats sucks! At minimum i would tape it and get some cheap wire loom on the exposed run after you clean it up of course.
56 minutes ago, SnowDrifter said:
Post some pics
are you going to recommend what i think youre going to recommend?
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Hey now I just want to see the damage first ;)
I would figure out how it happened because it will happen again if you don't.
Pioneer 80PRS
I still have no clue how to upload pictures. I know I need to use photobucket I think but that's it.
I'm thinking about getting a coupler I found online. I think I could get enough slack to get it. Then wrap the fuck out of it with tape and loom
Could you just add a fuse there at the break? Cut off the damage, connect ring terminals, and conect both ends to a fuseholder. That would be easier than ur adding more wire and using two fuse holders. But really u SHOULD replace the whole thing lol and maybe run the new wire higher so it doesnt happen again.
Lol I know what I should do. But thats not happening. If it becomes a problem I will. But I've had it installed for probably a year and this is the only damage I've had. I'm thinking not even a fuse, just a coupler. Besides maybe a tad more resistance but should be fine.
I would fuse it but I think the plastic fuse holder would be a huge risk of breaking
  • Who's Online   0 Members, 0 Anonymous, 4226 Guests (See full list)
