audiofanaticz Posted January 15, 2017 Report Posted January 15, 2017 Here is a enclosure for a pair of CT Sounds Tropo 8v2 subs I just finished. Just need to get it packaged up and on its way to Lufkin Texas it goes! Had to make a new port, I remembered the wrong and not the number I needed to cut off and the port came up too short. Glad I caught it before gluing it in otherwise the entire box would have to be rebuilt. Didnt feel like cutting down my new 4by8 sheet of HDPE to make some router templates, so I just used some scrap wood to cut down to get the job done. Just a simple brace since the space was tight inside the box, adding a center line of the brace would reduce the opening down from 60sq inches and make it awfully close to the cone area and that is no bueno! Cut out a second piece to beef it up without reducing the area, and hit it with a small Sweep bit. Also used a medium sized Sweep bit on the end of the port. Had to wait for some orders to show up so I could progress on the build, needed to measure the new style SMD terminals for the cutout, and was pretty much out of wire as well.
audiofanaticz Posted January 15, 2017 Author Report Posted January 15, 2017 Perfect fit, the larger cutout is for the carpet gap. Crimped, soldered, and covered with some SMD heat shrink. No more pesky black/red rubber boots. Looks so much better! Got the wires attached to the SMD terminals. Terminals are installed. I guess I forgot to take pics during the carpeting process. Oh well.
ShadeTreeMechanic Posted January 15, 2017 Report Posted January 15, 2017 Strong looking box turned out great! I like the ring around the inside of the terminal cup. Really beefy! 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Ron36 Posted January 15, 2017 Report Posted January 15, 2017 Get work super clean 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery
Ron36 Posted January 15, 2017 Report Posted January 15, 2017 I love those ring terminals that have the roughed edges so u don't need lock washers 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery
twalker182 Posted January 15, 2017 Report Posted January 15, 2017 Hope owner post install pics....... 2010 Accord Sedan XS D3400R Clarion HU Sundown mids and highs Incriminator amps Incriminator Lethal Injection 12"
ShadeTreeMechanic Posted January 15, 2017 Report Posted January 15, 2017 1 hour ago, Ron36 said: I love those ring terminals that have the roughed edges so u don't need lock washers That's cool, I didn't even notice at first. Gotta get some, where do they come from? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
audiofanaticz Posted January 15, 2017 Author Report Posted January 15, 2017 8 hours ago, Ron36 said: I love those ring terminals that have the roughed edges so u don't need lock washers The top not in the smd terminals have those too! 6 hours ago, ShadeTreeMechanic said: That's cool, I didn't even notice at first. Gotta get some, where do they come from? Ive been ordering Tspec terminals for a while, they seem to be fairly nice. Tspec is the old Tsunami brand.
Ron36 Posted January 15, 2017 Report Posted January 15, 2017 Thanks. 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery
meade916 Posted January 26, 2017 Report Posted January 26, 2017 damn!!! you always knock it out of the park!!! that thing looks great! All SMD products + MORE available at my store here! https://wccaraudio.com/ Subscribe to My Youtube Channel! Over 1,000,000 subscribers strong! Turn on your notifications! http://www.youtube.com/meade916 Follow My Instagram! Daily live feeds from the shop, exclusive content way before it hits my Youtube channel...and little squares with photo's in them http://www.instagram.com/meade916 The Official SMD Facebook fan Page https://www.facebook.com/SteveMeadeDesigns/ Follow my Tweet (Twitter) http://www.Twitter.com/meade916
