2 minutes ago, Blake21 said:
I'd like to keep all mine in the doors but if I put a 8" mid bass in each door with a super tweeter it should keep up? Or will a 6.5 mid bass and some tweeters do just as good?
If you are looking for all out loud, only one pair of super tweeters is all you will ever need. I do not even park near a vehicle that has them ...
Fab your tweets up on the A-Pillars and you should be fine with that.
Door treatment will be key with what ever direction you go.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
That's what I'm going for is ridiculously loud but I want it to sound good to, I want it to have a ton of bass but I want the mids and highs to match the bass . I can work with the a pillars, never done any fiberglass or anything like that but I'm sure I'll figure it out
What do you mean door treatment? Sound deadening?
2 hours ago, White Lightning said:
I had a single 8' driver with my components on the dash. No problems keeping up with the heavy, well tuned bass setup.
Well treated doors is a must with powerful drivers to give you tonal accuracy. Good Luck my friend.
Dig'n those dash pods. Im thinking of how i could do mine up there like that on axis. Do yu have a build log of those dash pods??
ECB7D4C8-AD0D-4496-8DAB-CBCBD594B828_zps
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
C1AF9761-0D3B-4194-A250-94D39DD2CE56_zps
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
There you go, SQ and SPL setups !!!
OMG, It's N8's build log!!!!!
Yeah, I believe they meant door treatment as sound deadening, etc.
Check out the products here, along with some good reading: http://store.secondskinaudio.com/    And also there's plenty of topics on that around here as well, I've seen many over the years.
97 Suburban
8 custom PSI Platform 3 18's
