Just finished my wall for 6 American Bass xfl 1222s on 2 dc 5ks
Each set of 3 subs on a dc5k @ 1.3 ohms tuned with Dd-1 (-5db) and gained matched with a cc-1
Broke in the sub for around 2-3 hours with a dc5k @ 4ohms on a 40hz test tone and then 30hz test tone thru the dd app
Just finished wall and have 5 subs broken in 1 wasn't so broke the one new sub then. Replaced sub with this new one I broke in for 3 hours seemed fine and was moving fine. So took it to slammology and was doing demos no issues then on 4th demo alsudden heard that infernal slinky sub noise.
So my question for you experts one what did I do wrong to blow the sub and what could I have done to prevent this?
What should my next step be?
1. replace the sub? And break it in complety this time before putting it in the wall
2. Send the subs out get reconed by Paul Pierce, psi, etc. With legit American coils and dual. 7s so they will take more power
3. Cut my losses and trade or sell the 5 good ab xfl 1222s and 3 blown xfls for 6 good 12in. subs that will take the Power.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Bumpidy bump
Yes sir. The rest our broken in this one I thought was broken in enough. Not sure what issue is all I know is this sucks and sick of dropping money to have same issue over and over again 2 subs in 2 weeks
Anyone have any thoughts or ideas on this??
not sure which track you used I Have found the only track that works for me and the systems I have setup is the max sound quality track, almost every big power system got stinky subs on any other track.
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
Damn, I dont know how I missed this one at Slam.  I was looking forward to seeing that stain in person!
Based on your impedance setup and overlap, I have no clue why you'd blow a sub with your setup man.  Sucks to go thru problems like this.
IG @walledsonic
The only thing I can think of is that for some reason the location of this sub doesn't allow for proper cooling. Or maybe having a stiff sub won't let it move enough for proper cooling. I wonder if there is a way to measure excursion to know when a sub is broken in or to be able to compare it to the others?
Pioneer 80PRS
Were the coils noticeably stinking before it blew?
IG @walledsonic
unloading?
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
