TEAM DEAF BONCE USA - (2) 32s | 48kw | 48 banks of caps
This build is crazy , can't wait to see it finished
2022 Ford Maverick on 22’s        Skar SK1500.1 on 4 Skar VD-8’s        Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4                                                 LC2 for audio control  , XS Power D680 XS Series Extra Battery
  • 5 weeks later...
Sorry, I've been away and left you all without an update, but here are some older photos. I'll get this thread caught up within the next few days. We ripped apart the interior and started working on the cage. As the last photo shows, the old recones take up the entire side to side space, which means this will be an interesting configuration.
Image result for Boner meme
Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born.
My penis is bigger than your penis
I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
Once cleared out, we started to work on the shell. We used 2"x1" steel. We elected to not go over the wheel wells in order to keep the rear AC and hopefully cool all the amps in the rear. We'll also have to mount the amps in some different positions because of the number of caps used. Anyways, here are some pics of us stiffening up the roof with 3/4" wood in between the stock slots (kerfed to contour) and then about 10 cans worth of about 3/4" foam between the wood and cage. It's not as stiff as the Alpha's roof, but it is a lot better than stock.
  • 1 month later...
Sorry for the lack of updates. We've just been busy. The inside of the cage is complete with sides and top. We used angle iron to get the angle of our baffles and used some massive bolts to secure the iron to the cage. The excess PL is just to make sure that the bolts don't back out LOL. We elected to use 1" trim pieces to make sure that the sides, top, bottom are 100% sealed because there were just some minor gaps in some areas. We traced the sub cutouts using a yardstick LOL. The subs fit perfectly in test fitting on the grass. But now one baffle is completely mounted. Things are coming together.
