Question about door pods
sTp
I used hot glue then just fiberglass, the fiberglass is very strong
2022 Ford Maverick on 22’s        Skar SK1500.1 on 4 Skar VD-8’s        Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4                                                 LC2 for audio control  , XS Power D680 XS Series Extra Battery
When laid properly its insanely strong, strong enough that most speedboats, jetboats, jetskis, fishing boats, cabin cruisers, yachts are all made out of fiberglass (granted some boats are made out of aluminum, and cruise ships and barges are mostly steel but you get  the idea).
A lot of Semis have fiberglassed parts such as their hoods, race car bodies, and so on.
So you shouldnt have an issue with speaker pods not being strong, your main concern would be where the door panel meets the pod since fiberglass dont really bond with plastic.
So what would be the best way to make it bond to the plastic i have uploaded a photo of where i will be laying the fleece and stapling it could you see a problem with my positioning?
https://imgur.com/a/sDrCF
On 2/5/2018 at 1:46 PM, WalledSonic said:
Did the hot glue stick well?  Curious, because even though the PL helped fill voids and definitely decreased rattles, it didnt adhere to the surfaces well so I would use something different in the future.  The expanding foam worked great though.
Hot glue sucks most of the time in my experience other than just stabilizing, for adding real strength (fleece and resin then fiberglass). It "sticks" but any real side pressure it pops off, for better adhesion, sanding a bit with epoxy (ca glue) works pretty well.
Good info man.
In my situation i was trying to squirt it into the crevices where the door panel pieces were plastic-welded from the factory. So sanding isnt possible. Hoping to find something that bonds straight to plastic as is.
IG @walledsonic
Once it's all been resined fiber glassed and filled surely it own't pop off (i am new to making pods these are my first ones sorry for all the questions)
If the material is wrapped around the edge, it wont pop off. But ANYWHERE resin contacts OEM plastics, sand it if possible, or even put tiny holes to let the resin grab into, because resin wont adhere to smooth surfaces. It will seem like it, but any twisting or anything (which happens as you drive around and the vehicle twists a bit) it will separate.
Guy's got a slight problem was stapling my fleece on my door's today and have come up with a problem near my 8'' pod i can't get the stapler close enough to the plastic door panel to create my line so was thinking about drilling some holes and tieing some wire to keep the line a little bit like stiching as i can't staple it closer otherwise it will hit the dashboard panel do you think this will work or if any of you have any other ideas for fixing the fleece to the door panels?
Right guys i managed to sort out the problem above and got a bit of progress this weekend i watched CAF video about fiber glassing and he gave me some good tips anyways i will let the pictures do the talking https://imgur.com/a/AxdI2
let me know what you guys think so far as this is the first time i have ever tryed to build door pod's.
  • Who's Online   1 Member, 0 Anonymous, 1088 Guests (See full list)
