conley916 Posted February 15, 2018 Report Posted February 15, 2018 My buddy sold me his Sundown 1500.1 and I was looking at two SKAR SDR-12s or two Sundown SA 12s for my 2015 Dodge Challenger. I guess I would just like to know the differences between subs besides SKAR being significantly cheaper. Thank you. 2015 Dodge Challenger Scat Pack audio coming soon
PaCiFiKbAllA Posted February 15, 2018 Report Posted February 15, 2018 Here's the difference: Skar Audio SDR-12 D2 - 12" Component Car Subwoofer Dual 2 Ohm Voice Coil Configuration Peak Power: 1200 Watts RMS Power: 600 Watts Competition Grade Pressed Paper Cone Stitched High Roll Foam Surround Advanced Air Flow Cooling System 2.5" High Temperature Copper Voice Coil Frequency Response: 32 - 300 Hz Sensitivity: 84.7 dB Fs: 32 Hz Re: 1.9 Ohms Qms: 6.76 Qes: 0.58 Qts: 0.53 Nref: 0.185% Cms: 0.11 mm/N Bl: 16.67 n/a Vas: 36.2 L Mms: 249.4 gr Sd: 471.4 cm² Xmax: 13.5 mm Specifications SA‐12D2 SA‐12D4 RE (ohms) 4.57 7.07 FS (Hz) 33.71 33.96 Vas (L) 21.21 24.63 Qes 0.58 0.55 Qms 5.34 5.15 Qts 0.52 0.49 Le (mH) 3.40 4.84 BL (NA) 21.64 25.67 Mms (Grams) 280 237 Cms (uM/N) 79.43 92.27 Sens (1w/1m) 83.21 84.22 Xmax = 16mm one-way by 70% BL RMS Power = 500-watts Vented magnetic gap featuring sixteen chamfered gap vents Solid Pole piece with chamfered edges for increased air powered voice coil cooling High velocity under-spider frame vents Black Aluminum 2” voice coil former for superior heat dissipation High Temperature copper voice coil wire Large Magnet ID aluminum faraday ring Spring Loaded Terminals Stitched-On “XL” Tinsel Leads to prevent fatigue and failure High strength & patented cast aluminum frame Optimized for small, ported enclosures 1 x Fi Audio SP4 V2 12" D2 Fully Loaded 1 x Wolfram W-4500.1 2 x XS Power D5100's 250A Singer Alternator 2.67 Cubes @ 29hz
alex912005 Posted February 15, 2018 Report Posted February 15, 2018 They look kind of the same on paper, both have 2.5 inch coils but the Sundowns have more xmax so should be able to get louder in theory. But versus threads are not allowed here because they generally turn into a shit show. My Build Log
anr102990 Posted February 15, 2018 Report Posted February 15, 2018 Not supposed to discuss “VS” threads, but the SDR series is new and I haven’t yet to know anyone who has them or have even seen them installed yet. Between the two I’d go with SA series. I personally have one skar DDX 12 at one ohm on an rp 1500 in stock electrical and it honestly moves quite a bit of air In my supercrew f150. Either way , build or have an enclosure built for it that’s right for your application. But anyways I believe the sundown sa series is pretty close in comparison to the DDX I have so I believe you would be satisfied. Good luck
WalledSonic Posted February 15, 2018 Report Posted February 15, 2018 One is a Chinese built sub built by a budget company and another is a Chinese built sub built by a quality company that wanted to introduce a budget line of subs. Either way, @PaCiFiKbAllA and @anr102990 nailed the responses. These subs are basically the same, just put one in a proper volume with a proper port and you wont know the difference. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
bsneon98 Posted February 15, 2018 Report Posted February 15, 2018 No one reads the rules anymore lol Build Log: http://www.stevemeadedesigns.com/board/topic/152954-1998-plymouth-neon-updates/
WalledSonic Posted February 15, 2018 Report Posted February 15, 2018 Since rent-a-modding is also against the rules, I add value where I can without trying to play mod or support versus conversations. Mods dont really moderate the forum very much these days, so its easier just to add value or avoid a shit thread altogether. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
ckeeler11 Posted February 15, 2018 Report Posted February 15, 2018 Sundown has a good reputation and builds solid products. Skar has a history of not being very customer friendly, and doing some shady things.
SkarredSierra Posted February 15, 2018 Report Posted February 15, 2018 You shouldnt bash a product because you have a personal beef with the owner.
ckeeler11 Posted February 15, 2018 Report Posted February 15, 2018 2 hours ago, mathewyocham said: You shouldnt bash a product because you have a personal beef with the owner. Just stating facts.
