CstrokerV Posted June 2, 2018 Report Posted June 2, 2018 ct sounds shafted somebody .. i thought he was a stand up guy. all well another brand i wont be running. was going to buy a 4 channel eventually all well my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
Crazy 8s Drums Posted June 2, 2018 Report Posted June 2, 2018 The clipping light on the Soundqubed bass knob was a feature I wanted and I am kind of bummed that mine doesnt work properly. It is good that DDs version does work...I may keep that in mind next time I go to buy amplifiers. Orion XTR amplifiers Skar subs
DiBo Posted June 2, 2018 Report Posted June 2, 2018 21 hours ago, WalledSonic said: Resolution is to get a RCA bass knob and an OM-1. Problem solved. I run 10K on this setup and subs dont get stinky anymore. What does the OM-1 do WalledSonic?
reedal Posted June 2, 2018 Report Posted June 2, 2018 2 hours ago, DiBo said: What does the OM-1 do WalledSonic? When set to the point at which your amp clips (via DD-1 or oscope) you can see if the signal going to your amp is clipped or not. Not all music is created equal, so if your amp is gain is set to a -5dB overlap, but the song you’re playing isn’t attenuated that much, then the OM-1 (which should have also been set to match the amp) will go red indicating clipping and you should turn it down until you’re no longer clipping. I love mine. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Masterbasser Posted June 14, 2018 Author Report Posted June 14, 2018 i never got the system playing like it should be, i had to go back and tune the amps with track 1 which is a 40 hertz 0db tone, once i tuned it with that it really came alive. strange never had to set anything but head units with the 0 db track..... wanted to update Kenwood excelon ddx795 3 370 amp CES alternators (audio side only) McLaren dome tweeters Crescendo 6.5 ultra neos NVX JAD800.4 4 PA x4 SPL 18's 4 Digital Designs m5's at .7 ohms each 2 K2 80 ah lithiums 3 group 31 agms Ledglow million color (12 piece) 2007 Yukon xl
WalledSonic Posted June 14, 2018 Report Posted June 14, 2018 Im currently set with 0dB for all my amps, but I'm leaving output on the table for songs with a lot of overlap, like DJ Russticals. Its perfect for DJSNT though. I clicked my head unit subwoofer output up a few clicks til I get around to retuning my sub amps with 5dB. Im overpowered a lot on my mids so Im leaving those at 0dB. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
Masterbasser Posted June 15, 2018 Author Report Posted June 15, 2018 it just seemed on -5 db track i couldnt get clsoe to where i had set it up to play max volume, i always had to drop subwoofer output -4 or -5 back from setting it at 0, or id get a lil stank on the woofers now i have no problem playing at the max volume i set it at with 0 db, no stank at all, plus hitting alot harder, cant wait to get 4th sub and 4th amp working properly i have to gather my pics and psot up a build log, the pics got pretty spaced out because of the extreme rush that occurrred the last few days of the build, had to really put in some 12 -14 hr days nonstop on it Kenwood excelon ddx795 3 370 amp CES alternators (audio side only) McLaren dome tweeters Crescendo 6.5 ultra neos NVX JAD800.4 4 PA x4 SPL 18's 4 Digital Designs m5's at .7 ohms each 2 K2 80 ah lithiums 3 group 31 agms Ledglow million color (12 piece) 2007 Yukon xl
