d-nice88 Posted December 4, 2019 Report Posted December 4, 2019 So I just got my replacement battery today and hooked up my bus bars and when I took one of the screws to check if it fit my copper lugs and i flippin dropped the screw in between the bus bars and it got stuck. After a few sparks I got it free. Checked the voltage still reads 12.97. Did I mess my battery up? Or will it be ok. It's a north star sms 220 batt btw.
will77530 Posted December 4, 2019 Report Posted December 4, 2019 Unless your battery has a battery management system built in like some lithium’s then you should be fine
Joshdashef Posted December 4, 2019 Report Posted December 4, 2019 The DMM shows good voltage then you should be fine. Check that when charged/installed it gets to the appropriate voltage (around 14.4) If you are scared of it to happening again put some electrical tape on the inside parts of the terminals. I do the same thing for my dual inputs that are right next to each other on my amp. SMD Tool Map (2024): https://www.stevemeadedesigns.com/board/topic/226545-smd-tool-map-2024/ Great Box Bracing Examples: https://www.stevemeadedesigns.com/board/topic/202148-best-way-to-brace-a-box/?do=findComment&comment=3055002
Jessica Posted December 4, 2019 Report Posted December 4, 2019 when i was a kid i once ran a chain between the positive and negative posts on a car battery to see if it would shock me. the battery was fine, i lived and nothing bad happened. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
d-nice88 Posted December 4, 2019 Author Report Posted December 4, 2019 Cool I appreciate the feedback guys. Definitely gona use electrical tape n some other shit to make sure that does NOT happen again.. lol
Mike4068 Posted December 4, 2019 Report Posted December 4, 2019 Lol, I did the same thing. I dropped my ratchet and it damn near welded itself to the bars. Destroyed the ratchet mechanism. My Northstar is fine though.
Joshdashef Posted December 5, 2019 Report Posted December 5, 2019 On 12/4/2019 at 9:42 AM, Mike4068 said: Lol, I did the same thing. I dropped my ratchet and it damn near welded itself to the bars. Destroyed the ratchet mechanism. My Northstar is fine though. Battery + Ratchet - SMD Tool Map (2024): https://www.stevemeadedesigns.com/board/topic/226545-smd-tool-map-2024/ Great Box Bracing Examples: https://www.stevemeadedesigns.com/board/topic/202148-best-way-to-brace-a-box/?do=findComment&comment=3055002
CstrokerV Posted December 6, 2019 Report Posted December 6, 2019 I hate bridging my arm across the posts.. I do it almost every time I’m messing with the battery.. sitting there wondering why my arm is burning my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
BassMunky Posted December 6, 2019 Report Posted December 6, 2019 it ok Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
