Reccomend me some subs!
Ipoksmote
I need somee recomended subwoofers that would suite my style, was hoping yall would wana share some ideas.
Edit--- forgot to explain my style, I'm a huge spl guy, I love vibrations and deep thunderous bass
Budget under $500 would be great, if its $500-1k, that's.....do-able but...not really. But if it's a must....
My vehicle  space is basically the same as those little chevy blazers (Mitsubishi outlander)
My charging system can supply 200amps for what I need.
I have 3 separate amplifiers (rms) ( all class D mono)
1k watt 2ohm stable
1.5k watts of constant power 1 and 2 ohm stable
2k watt 1 ohm stable
Hmu with some recommendations on subs and if their website doesnt have enclosure statistics I suppose I would need to know those too.
Thanks!
Also, if yall wana help me understand what I should look for in specs that would be cool.
Right now I just look at rms and xmas, and largely base my purchases off what I find on forums and comments and etc.
1k watt 2ohm stable
So your saying you have three different kinds of amps you want to run on three subwoofers in the same box? Sorry if I'm missing your point. Just a little confused on that part...
Run a trio of beefy 8s.
Sound solutions evl8. 3 on that 2k amp
3 dual 4 subs parallel could parallel to each other for .66 ohm at amp. Should be fine after rise
Skar, american bass, soundqubed. All have higher tier lines in your price range. U want spl? 2 skar zvx 18s would be about as big as u can get but itll be tight and come above the seat line. Another option is 4 12s. You can fit them snuggly with a lil room left for batts and amps. I had 4 12 in a 93 s10 blazer is how i know. Lol.
American bass xfl....u want brutal that's ur ticket. Or xr if u need some SQ in there too.
No he was saying he had 3 different amps he can use to power the subwoofers he is asking for advice about .....I'm pretty sure atleast!
Had a single xfl12 in my lil 98 blazer on 2k and it was retarded,no one could believe it was a single sub till I actually showed .
  • Who's Online   0 Members, 0 Anonymous, 745 Guests (See full list)
