I know if your port is too small you get port noise. What happens if its too big?
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
i would guess it would have no lows at all and sound just like a woofer movin without much sound. if im not right or close ill be learnin too :D
The only thing that happens with a huge port is give you a way high tunning freq. 60hz and up if you try to play lows it will blow your subs
I had a box for 2 10's port was so big I could stick my head and shoulders in the box and wire the subs at 66hz the freq. Of my truck I burbed a 147 with some earthquake subs
Edited by Team Bassick (ALPINE)
Depend how big? I like big port because it give you hair trick and air movement.
It doesn't matter how BIG the port is, as long as it's tuned to the same frequency. A huge port will need to be longer in order to keep the same tuning.
I really believe that big ports can be more efficient, but you end up gobbling up your enclosure space pretty quickly when you start opening the port. In car audio, it's all about Compromise.
  • Who's Online   0 Members, 0 Anonymous, 2125 Guests (See full list)
