http://seachoice.com/productdetail/ProdDetail.asp?pid=32477
why not use something like that instead of all the little wires?
I really like that piece. I just wished I knew about it before I spent all that time trying to make my own buss bar creation. We all learn new ways and new products all the time.
BlockShaker's Competition Page and Build-Up Pics
MY SET UP:
Eclipse CD5435 CD/MP3 Player
Alpine DVE-5207 DVD Player
Alpine PKG-1000 10.2" Monitor
Alpine TUE-T151 TV Tuner
Boyo Back Up Camera
Alpine ERA-G320 EQ
Apple Mini Ipod
Scosche RF Wireless Remote for Ipod
Stinger Volt Meter
Audiocontrol MVC
Precision Power PCX-2400
Precision Power PCX-4125
MB Quart Premium PCE-215 (2 Sets)
MB Quart Premium 6 1/2" Mid-Bass
JL Audio 15W0-8 (8)
Stinger Battery Power2 SP1000 (2)
Stinger Fuse Blocks, Holders and Distribution
Alumapro 15 Farad Cap
Stinger 200Amp Relay
100 Blue LEDs (Headliner and Amp Rack)
Stinger Hyper RCAs
Stinger Wiring- 1/0 GA, 4 GA, 8 GA, 10 GA, 12 GA and 14 GA
5 Blue LED Toggle Switches
okay i have a question...
Say you have 2 amps (keep it simple) and you use that bus bar idea. You obviously have to have a constant 12 V connected to the bus bar, the REM wire from the head unit to the bus bar, and a ground from the bus bar to the metal of yoru car. Then you have 2 REM wires going from the bus bar to the 2 amps. Well my question is, do you only need ONE constant 12 V connected to the bus bar, or 2, since there are two REM wires going to two individual amps. Also, same for ground, do you need ONE ground going from the bus bar to the metal of your car, or two grounds.
Baylor University
Accounting
keep it real simple and just stick to the relay, wire it up as said and your done... no bus bars or xtra confusion for a first timer
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
alright but can someone answer my questions so i know about the situation though. I guess i would only need one 12 V source and one ground since if i used a relay i would only use one of each for 2 or 3 amps anyways cuz thats how it is set up.
Baylor University
Accounting
correct one + and one -
"Using a 30 amp SPDT relay, connect terminal #87 to constant 12 volts positive (with a fuse rated 200 ma for each amplifier. optionalbut a good idea.) Connect terminal #85 to ground, terminal #86 to the remote turn on wire from the head unit, and terminal #30 to each amp.
Scientia est Vox
dude what? do what roscoe said. the way youre stating it, that i can read, is that everything is connected to one buss bar. you cant have a power and a ground connected to the buss bar. hell, if you connect the power and the remote to it, your amp will never shut off.
