im on a very low budget andm im trying to find a sound deadener to but on my trunk to stop the rattling my 15 is causing. i heard peel n seal works like dynamat? if thats true where can i get it? what do you guys reccommend?
Sicc 2 Sicc
SMD FOR LIFE
for a budget go for it. a few of us have used it , prob not as sticky and thick as real deadener but it does work. i find it at lowes around here but prob can find it at most home improvment places in the roofing section
I'd recommend second skin damplifier or damplifier pro depending on your budget:
http://secondskinaudio.com/products/Acoustic-Car-Audio-Noise-Reduction.php
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
Edead can be had for a dollar per sq. ft.
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
edead pretty much is peel and seal
Extremely High Temperature Adhesive Whether you live in Colorado, California, Michigan, or Florida you do not want your deadening falling off when it gets HOT!. The eDead adhesive is designed to withstand extremely high temperatures.
straight off there sight.
| S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s |
SPL: 143.7 Sealed | 153.4 Port Wars
