might have pinched the wire when it tore the coating off.
Give it a good inspection, if its broken just cut it then get some heatshrink for 0 guage and a butt-connector. Shouldnt be more than $10 I would think. Would be a good idea to crimp the connector, can get all the parts from a local large electrical store and they might even lend you the crimper.
Hammerdown... 1%
^x2 the wire was probably damaged.
The best fix would be new wire though, but if you don't have enough monies, use this method^
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
i had my run from alt to batt slip off of where it was supposed to be and rest on a heat sheild of my exhaust burned through half the wire and i didnt have and problems other than the sparks. scary shit
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
Am I the only one who thinks this is a really bad idea?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
the wire parching? ha id say replace it, easy and most effective as far as the messed up wire goes. then you will really see if its the prob and it needs to be done anyways
It is the wire. I climbed under today and checked it with a multimeter. More than half of the wire has been grinded off and it's all corroded and crap. Don't know how ima fix it yet. I can't afford a 15' strand of 0G due to the fact I don't have a job. So I'll figure something out. Thanks to eveyone.
Them: "Why does my amp keep cutting out?"
Me: "What is your ohm load?"
Them: "What's an ohm load?"
http://www.darvex.com/SPT8210/Stinger+0+Gauge+Wire+Coupler.html
this should do the trick and it seems to be safer than all other ideas
(Headunit) Pioneer DEH-P3100UB
(Speakers) Phoenix Gold RSd 65cs
(4 Channel) Alpine MRP-F300
(Subs) 2 15" Audioque SDC2.5
(Box) 7.27 cubic feet tuned to 31 Hz
(Mono Amplifier) Elemental Designs Nine.1
(Wiring) 1/0 Knukonceptz KLMX
(Batteries) 2 C&D Tech 75 a/h
Safer? No.
Work fine? Sure.
Hammerdown... 1%
  • Who's Online   0 Members, 1 Anonymous, 2004 Guests (See full list)
