Amp Test Tuesday - Mmats Pro Audio 2000.1 D + Gut Pics - Guess the power Win Something! RESULTS page 7
the latest amp about to be tested on my youtube series "Amp Test Tuesday" is this Mmats Pro Audio 2000.1D. Rated 2000 Watts at 1 ohm @ 13.8v. Of course my bench consists of 10 XS Power D1400 14v batteries which means final testing will be at about 14.5-14.6v DC. But that's ok! Most cars charge above 14v anyhow so it is a good indication of whether or not it can make it's claimed power. If anything, i am giving these amps about as fighting of a chance as i can.
Anyhow, here is what we are going to do.
Tested with:
SMD D'Amore Engineering AD-1 Amp Dyno
Power Supply used for testing:
10 XS Power D1400 14v Batteries
1 XS Power HF1415 15a Charger (not a power supply)
The amp was tested @ 1ohm (Rated 2000x1 RMS) and @ 2ohm (Rated 1100x1 RMS)
There are 3 test modes used Certified, Non Certified and Dynamic Burst
2ohms
Certified mode (test stops at 1% distortion) - x,xxx Watts RMS
Non-Certified mode (test stops at clipping) - x,xxx Watts RMS
Dynamic Burst RMS (test stops at clipping) - x,xxx Watts RMS
1ohm
Add these 6 results together and post the final number as your guess.
The member who's guess is closest to the correct number wins a set of Mmats Pro Audio Mids/Highs! YES, the closest! That means SOMEONE will win these for sure! If two people get the closest number, but one is low and one is high, the person who is on the high side BUSTS! He loses. So don't over guess! Also, if there is two of the same number, the person who posted first will get the prize. So make sure your guess was not already posted before you post it. If someone changes there guess (which is allowed up to the last hour), we will see when it was changed and that will be your new date. So if you re-guess, make sure your new number has not been used or you might lose! :)
You get ONE guess. Post it and that will be your entry into this contest. Simple! You MAY edit/change your number up until about an hour before i post results. I WILL go through each and every post before i upload the video so if you try to change your guess afterwards, i will know. So don't try it. Just make a guess and wait. :)
OH and who wants a side-bet? If anyone here hits the EXACT number, i will give you $100 towards any SMD product on my webstore http://www.wcCarAudio.com
You guys have until Tuesday, February 9th at about 12 or 1pm Pacific time - so lets see those guesses! Before you guess, check out the GUTS below! Good luck!
  • Like (+1 Rep) 3
Follow my Tweet (Twitter)
Rated at .05 ohms? Must be a typo.
Pioneer 80PRS
where do you see that?
In the picture of the spec sheet.
Pioneer 80PRS
Where it says "Watts @ .05 ohms mono" on the left side of the picture of the spec sheet.
Pioneer 80PRS
