Wats the best saw/blade, or a dremel or sumthin to cut plexi glass witout crackin it, it's only 1/4 inch thick
Do you read ur own response b4 you post?...or just type ur gut reaction and headbutt the enter key? :blink:
How bout this, the Caddy sounds so damn good it can put a smile on a "deaf mans" face :)
mat then mix hardener into resin and soak mat. beeeeeyaw glassing for n00bs
and if your shaping it, use a router, and some wd40
I used liek a 120 tooth blade when I cut some 1/4 plexi, but you better hold it tight to the surface your cutting it on like a table saw. It has to be flat or it will crack cause when you go to cut the blade will make the plexi raise up some so you got to hold it down tight.
"MY RIDE"
1987 Chevy Cavalier Z24 2.8L V6 -- CB Radio with PA speaker
Head Unit: 7 inch Jensen Flip-out -- Speakers: 4 Visonik 6 1/2s and 4 Visonik 6x9s
Subwoofer: One Audiobahn 18 - Sub Amp: Power Acoustik OV1-2000d 2000 watt monoblock amp --
Battery in back - Kinetic HC600 -- Sub box: Custom built 5 cubic foot tuned to 30 hertz
Coming soon: Bigger Highs Amp, Power inverter
"WhItE bOi AuDiO"
"FEAR THE DUCK"
I usually just pickup whatever the finest tooth blade home depot has in stock for a jigsaw. As stated before hold it down or it will crack on you!
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
cut a piece of 1/2 or 3/4" mdf to the size/shape you need then get some strong two way tape and sucure the plexi to it, then use a flush trim bit to copy the shape to the plexi! Yes even if its a square or rectangle this method works great!
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
was watching tv today and some guy was using a bandsaw...although, im sure not many of us have access to one of those
i likes me some audio stuff...
a dremel will more than likely melt it. been there and done that.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
cut a piece of 1/2 or 3/4" mdf to the size/shape you need then get some strong two way tape and secure the plexi to it, then use a flush trim bit to copy the shape to the plexi! Yes even if its a square or rectangle this method works great!
That way works and if your using a table saw to rip a sheet down, use a piece of scrap wood over the top to hold it down.
  • Who's Online   0 Members, 0 Anonymous, 1379 Guests (See full list)
