This is for a regular customer, good friend of mine. He just had a kid, and decided to go with home audio this time. Original plans were 4- 6' mid's and 1-2 tweeter dipole design. I looked and looked for the right mid's for him, and the budget, and nothing intrigued me. I decided to go ALL custom mid range, woofer, crossovers, everything.
I ended up thinking dipole, mid up high, tweeter middle- 36-38" high, sitting ear height , bass down low, 200hz lp
I had some so called subwoofers here, 8" that were dropped off courtesy of Rednavi, and I had thought about making them in to mid range speakers. I ordered some parts, did some testing- BAM. very flexible, great sounding mid range from 100-4000hz. After testing, I found they mated very well with a Vifa tweeter set and crossover set I had used before.. The response and clarity was pretty incredible. This is when I didn't have to build a x-over, so I was happy.
I attempted to build a low power sub/mid bass, but ended up being a very efficient overall bass driver. In my testing, it is Bi powered- 240w rms to the bass, and 60w to the highs. Amp being used is a HK AVR7000 in 2 channel mode I believe was 120w per channel
Pics suck, it was 100% from my phone
The Midrange 8"
So fun doing these speakers over subwoofer. Dealing with 50grams moving mass, 2 layer 0.375 long coils is so diferent and very pleasing in the end result
Some Build pics
Midrange beauty baffle
The rough build/assembly. still needs final coats
side view/port area. The baffle has an angle between the tweeter and mid due to imaging/time delay. I wanted the best. This is similar to building custom kick panels/door pods specifically for SQ. The angles, height of the tweeters, angle of mid pointing down ward is all important for best imaging. The front feet twist to adjust for how close the towers are to the listening point by almost 5degrees.
crossover and mid, all hooked up. Access panel going on, sealed with expanding weather stripping.
Edited by Forevrbumpn
I'am pretty disappointed with how GLAREY the pictures look, I may use my dedicated digi cam to to better detailed pictures of these in and out.
looks VERY nice!! great job man!!
Follow my Tweet (Twitter)
Man this so freaking clean.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Thanks guys...
Yes that is a removable port. Originally designed sealed upper and lower, but I couldn't build a woofer that would be efficient in a 1.6cf sealed with about 60
watts
So a port was designed and threw in
