I got a pair of Massive Audio DC 10's and i was wondering if anyone could help me with a box design. I want a box good for SPL as well as a decent daily box. Preferably Tuned in the lower to mid 30's or higher if i can still play into the 20's. I mainly listen to decaf and big pimpin. Thanx.
Pioneer AVIC F900BT double din
Stinger digital volt meter on dash
1/0 guage power wire positive and negative
Interstate 117ah battery in the back
2 runs 4 guage power wire from rear battery to amp
Power Acoustics Stax 5500
4 Powerbass m-15's(old style)
2 sets o2 5.25 inch components in front
2 Sony 5x7 in back
Sony 500 watt 4 channel
Post your maximum dims and I will give you a suggestion.
I can get 42 wide and no restriction on depth and height because its going in an explorer with back seats removed and a false floor to extend the trunk/hatch are all the wat to the front.
2 Sony 5x7 in back
Ok so here is a design suggestion will reach F3 = 28Hz before cabin gain:
Enclosure Specifications:
Fb = 32 Hz
Vb = 2.607 ft^3
Subwoofer Mounting = Front Mounted
External Height = 12 in
External Width = 41.75 in
External Depth = 16 in
Port Width = 3 1/2 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 37 1/2 x 10 1/2
Back = 41 3/4 x 10 1/2
Left & Right Sides:
Side 1 = 14 1/2 x 10 1/2
Side 2 = 15 1/4 x 10 1/2
Top & Bottom = 41 3/4 x 16
L Port Internal Assembly Parts:
Front to Back = 11 x 10 1/2
Extension = 14 1/2 x 10 1/2
Brace = 4 x 10 1/2
A rectangular brace is recommended between the subs, any questions let me know.
Edited by Joe X
Yes there is. Its a 99 explorer sport.
Edited by michael_woodworth2000
2 Sony 5x7 in back
If u don't mind, could u design me a box for 2 15s in 1 chamber then 1 15 in a separate chamber so it looks like one box. The 2 15 will be massive audio and the single 15 will be a Dd 3515
2 Sony 5x7 in back
mind explaining why an odd number of subs are bad?
if you get 3 subs and have 3 amps to power them, i don't see what's wrong with thtat..
even if you only had one amp...
as long as they're the same sub.
Edited by 412 CVX
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
  • Who's Online   0 Members, 0 Anonymous, 1000 Guests (See full list)
