To fuse or not to fuse.
Should you or should you not use a fuse between a battery and your sub amp?
34 members have voted
  1. 1. To fuse or not to fuse?
So how come i see a lot of guys not running inline fuses from there battery bank to there sub amps? I always fuse between everything and wondering now if you should go with out it? seems sketchy to me. idk whats your opinions on this.
2003 VW Jetta Wagon AA Mayhem 15's Flatline BA2 2 XS D3100's in rear Shuriken BT80 under hood
Mike Singer 250A SHCA and KnuKonceptz wire Big 4+
AQ / Dayton pro mids+monsoon tweets
My Build : http://www.stevemead...35#entry1989435
i always fuse because if your in a wreck and a wire gets pinched or something it would short out your amp so the fuse would blow instead of anything else
Positive between battery and amp would not short your amp...it would short the battery causing the wire to overheat/melt/cause an electrical fire.
Some amps have fuses on them some dont...the ones that dont it is usually recomended by them that you run another fuse right before the amp also. Never run your wire without a fuse. It is unlikely that it will short..I have never popped a fuse...but if it does happen do you feel like burning your car for a 10$ fuse holder.
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
There is no reason not to fuse. If the amp is already internally fused, well, then it is already fused.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
You fuse to prevent a fire, not to save your amps.
Long story short, unless your vehicle is worth less than the cost of a 300a ANL ($0.90) or you don't have the room, fuse it.
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
2 270a Mechman Alts
We had a guy at a local small event with no fuse. Guy seemed really knowledgeable about everything. He went to the db tent and not even 20 seconds into his bump something went wrong and his truck went up in flames. All he posted on facebook was his battery wire came loose and sparked and up it went. Clean install and engine. So, Ive been very curious what really happened. For me, If I am running any wire from the battery it is fused. Just to be on the save side.
Current system (still building) 2 kicker 12" dcvr in factory kicker ported box, Rockford Fosgate 1200.1 Amp, Kenwood ddx-470 ddin radio, Rockford Fosgate 0 Gauge wiring, Rockford Fosgate punch 6X8 2 way speakers.
  • Who's Online   1 Member, 0 Anonymous, 452 Guests (See full list)
